Brake noise???
Results 1 to 3 of 3
This is a discussion on Brake noise??? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I just put on aftermarket rotors, with thanks fully to this forum on brake application . I followed steps to ...
    Registered User mridrive10's Avatar
    Aug 2010
    Hot Springs, SD
    Exclamation Brake noise???
    I just put on aftermarket rotors, with thanks fully to this forum on brake application . I followed steps to a T but now i have a weak grinding type noise (which sounds like its coming from just the rear wheels). I doesn't do it when i start the car, but after a little bit of me toying with it it does. It happens all the time but it appears to not be messing with my braking because the car is easy to push and make roll. Any thoughts? please hit me back asap!!!!
    Apr 2007
    8000' up in Colorado
    It sounds like just a simple rubbing problem with the pads on the rotors. What type of pads are you using? Did you replace them when you replaced the rotors (you didn't need to, just curious)? Do you have the shims in or not?
    Scott
    Aug 2010
    Hot Springs, SD
    I replace pads and rotors. not sure the brand but everything that came off basically went back on. i assumed it was a rub too but its not like stopping or slowing the car any...
