Rear Caliper help
Results 1 to 4 of 4
This is a discussion on Rear Caliper help within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; My rear drivers side caliper on my 03 WRX wagon has no movement. The caliper and flex hose has been ...
    Registered User scoobyltd's Avatar
    Aug 2010
    Rear Caliper help
    My rear drivers side caliper on my 03 WRX wagon has no movement. The caliper and flex hose has been replaced as well as the master cylinder and still no movement. Could it be the line going back to it? If so how do I get to it? The car stops great still and does no pull at all while slowing down but the caliper isn't grabbing. The rotor is surface rusted everywhere. What do you guys think?
    When in doubt, flat out.
    Bugeye Mafia v2.0 #333
    Black N' Blue/03 WRX Wagon/3" TBE/Catless Up-pipe/17" DxR Rims/Lots of tint
    Aug 2010
    None of you guys have messed with brake lines on theses things?
    May 2005
    Phillytown, PA
    You are positive the piston isn't moving? Have you tried pushing it back into the caliper?
    Have you checked the sliders? Do they move as they should?
    The brake line is held in under the car with plastic clips. You simply have to follow it forward from the caliper. I also doubt it is the problem.
    Jan 2005
    Eh, whaaaaa?
    When you replaced the caliper and hose you had to have bled the brakes (if you didn't, there's your problem), if fluid moved through the lines just fine when depressing the brake pedal, it would seem that the caliper is the issue again, not the lines.
    Cody
