Page 4 of 4 FirstFirst 1234
Results 46 to 56 of 56
This is a discussion on Boost fluxuating, data log within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; i will give it a try but the only problem is on my accessport i do not have Knock Learning ...
  1. #46
    Supporting Member yamaha_rider619's Avatar
    Jul 2009
    colorado is home, Kansas is the temporary home
    i will give it a try but the only problem is on my accessport i do not have Knock Learning (deg)[AP] or Fine Learning Knock Correction (degrees)[RR] or Knock Correction (deg)[AP] or Feedback Knock Correction(degrees)[RR]. I talked to kevin about romraider, but my ap cable is different than everyone else's v2. I dont have a dongle, it goes from the obd to a serial port on the ap.
    Josh
    2003 Subaru Wrx Vf39'd
    Bugeye mafia #300
    Sponsored By: WRXPro.com
  2. #47
    Oct 2005
    Late Devonian
    Quote Originally Posted by yamaha_rider619 View Post
    Hmmmmm. Update your firmware? That stuff should all be available if you have a V2.
    Is it like the V1 cord? If so try plugging it in and running romraider (worked fine with mine once you find the correct port).
  3. #48
    Jul 2009
    i cant plug it into the computer. The cord is obd to serial port of some kind. Not a normal computer plug. They updated it for 2003 wrx's. just updated the firmware as well last night.
    Josh
    Bugeye mafia #300
  4. #49
    Oct 2005
    Late Devonian
    Ug. Sorry to say but I am ever more glad I moved away from AP.
  5. #50
    Jul 2009
    Yeah i hear a lot of pros and cons from them.
    Now the dealership says cannot find the right restrictor pill size, they say all wrx after 2005 are the same.
    Josh
    Bugeye mafia #300
  6. #51
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    I told you that I have the cable... we can do romraider/learning view on my cable.
    There is a parts "blow up" hanging around nasioc somewhere... find the exact part number for the restrictor pill, and just call and order that part number.
  7. #52
    Jul 2009
    Yeah i know, let me try to pill first, then we can go from there.
    It took a while but i talked to subaru of america, and they didnt know what it was, a local dealership and finally a farther dealership found it. Go subaru west is now great in my book.
    Josh
    Bugeye mafia #300
  8. #53
    Nov 2006
    Denver Metro Area
    I used to have that pill (brand new too... I made the guy that threw mine away at superrupair buy me a new one)
    I'll try to find it.
  9. #54
    Moderator Donkey's Avatar
    Da boonies
    You probably need to check for boost leaks and preturbo exhaust leaks to rule them out.
    2002 FORESTER S
    1998 FORESTER S
  10. #55
    Jul 2009
    Well cobb was right. I just need to restrictor pill that the 2006 turbo was meant to use. After i got it from the dealership, i installed it right then. Reset my ecu and drove it. Got my full boost again!
    Josh
    Bugeye mafia #300
  11. #56
