Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 56
This is a discussion on Boost fluxuating, data log within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; will do thanks...
  1. #31
    Supporting Member yamaha_rider619's Avatar
    Jul 2009
    colorado is home, Kansas is the temporary home
    will do thanks
    Josh
    2003 Subaru Wrx Vf39'd
    Bugeye mafia #300
    Sponsored By: WRXPro.com
  2. #32
    Moderator Donkey's Avatar
    Da boonies
    The 06+ WRX turbos are slightly different than the 02-05 WRX turbos. You can try swaping the wastegate actuator from your old turbo to the new one and see what happens. That is one difference,the preload in the actuator. The other main one is the wastegate ramp in the turbine section. You should have also observed that the compressor housing outlet is slightly shorter as well.
    2002 FORESTER S
    1998 FORESTER S
  3. #33
    Jul 2009
    How hard would it be to swap the wastegate actuator?
    "The other main one is the wastegate ramp in the turbine section."
    Is this a problem?
    Josh
    Bugeye mafia #300
  4. #34
    Quote Originally Posted by yamaha_rider619
    Not difficult. Probably a half hours worth of work.
  5. #35
  6. #36
    Oct 2005
    Late Devonian
    The old one seems like it was having problems though.
    Why not just try tightening it a half turn at a time - just make sure it doesn't start spiking or overboosting anything.
    I'd get a 3-port BCS if going to the trouble of a protune.
  7. #37
    Jul 2009
    I agree with the old one seeming bad.
    which way would i turn it, clockwise or counter? EDITI saw you said tighten)
    Also how would i know if it is spiking and over boosting? Would the overboosting be over the suggested 15psi?
    Oh and im assuming since no one said anything, is it okay to drive? As long as i dont push full boost?
    Last edited by yamaha_rider619; 08-19-2010 at 09:25 PM. Reason: realized i cant read
    Josh
    Bugeye mafia #300
  8. #38
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    absolutely
  9. #39
    Oct 2005
    Late Devonian
    Quote Originally Posted by yamaha_rider619 View Post
    Spiking as in it overspools up to e.g. 18 or more briefly before settling at 15 or overboosting as in exceeding the target or possibly running away (basically creeping).
    You need to read the user guide and figure out how to change what you are logging. "DAM" is the best indicator of how safe you are running, along with knock correction.
    http://www.accessecu.com/support/docs/DataLog.html
    http://www.3gwrx.com/forum/index.php?topic=8062.0;wap2
    You should be logging the following:
    RPM (RPM) [AP] or Engine Speed (RPM) [RR]
    Calculated Load (load) [AP] or Engine Load (1 byte) (g/rev) [RR]
    Dyn. Adv. Mult. (DAM) or IAM [RR]
    Knock Learning (deg)[AP] or Fine Learning Knock Correction (degrees)[RR]
    Knock Correction (deg)[AP] or Feedback Knock Correction(degrees)[RR]
    Throttle Position (%)[AP] or Throttle Opening Angle(%)[RR]
    Boost (PSI)[AP] or Manifold Relative Pressure(corrected)(PSI)[RR]
    Mass Airflow (g/s)[AP&RR]
    Wastegate Duty (%)[AP] or Primary Wastegate Duty Cycle(%)
    Turbo Dynamics (PSI)[AP]
    Target boost or boost error (only need one)
    You should also be checking for A/F corrections but I'd do that in a separate log without the WGDC, Boost error, and Turbo dynamics (to increase resolution). Add injector duty cycle for that.
    It should be safe to log that now given your boost is so low, but check to see that your DAM is up (16 is max on your car, less is not good) before doing a pull. Figure out how to do that and post it up or there is really no way to tell other than just tinkering around.
  10. #40
    Da boonies
    Who installed the turbo?
    2002 FORESTER S
    1998 FORESTER S
  11. #41
    Jul 2009
    I installed the turbo
    Josh
    Bugeye mafia #300
  12. #42
    Jul 2009
    I just spoke with cobb and they told me to try a restrictor pill from a 2006 wrx and that should fix the issue.
    2003-2005 WRX WGDC Tables
    Stock restrictor pill size = ~.047”
    Factory wastegate pre-tensioned to ~6psi
    2006 WRX WGDC Tables
    Stock restrictor pill size = ~.028”
    Factory wastegate pre-tensioned to ~6psi.
    If it doesnt he said to get a 3 port bcs and a pro-tune.
    What do you guys think about trying the 06 restrictor pill?
    Josh
    Bugeye mafia #300
  13. #43
    Apr 2007
    8000' up in Colorado
    I think you should listen to what Cobb says. Did you talk to Chris there?
    Scott
  14. #44
    Jul 2009
    I don't know who i talked to, i called the location in Plano, Texas. Do you know which one Chris works at or have his number?
    Josh
    Bugeye mafia #300
  15. #45
    Oct 2005
    Late Devonian
    Definitely sounds worth a try. I didn't know they came with different sizes.
    The smaller restrictor pill will limit the amount the BCS sees, so it can bleed off pressure more efficiently before sending it on to the wastegate actuator. That should drop WGDC and increase boost. I'd still watch closely and the log I suggested is still a very good idea.
    If it doesn't work you could also just run the line straight from the turbo to the wastegate actuator and figure out what pressure it runs on its own. Or as we said before, just get the 3-port. XPT has a map for it so you could do an etune with them.
