Stock Turbo trouble
Results 1 to 15 of 18
This is a discussion on Stock Turbo trouble within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I bought a 2004 impreza wrx 2.0T about two weeks ago. I over looked the boost gauge when i was ...
    Registered User TurboTransport0's Avatar
    Aug 2010
    jacksonville.FL
    Stock Turbo trouble
    I bought a 2004 impreza wrx 2.0T about two weeks ago. I over looked the boost gauge when i was purchasing it because everything under the hood looked exceptional. As I started driving I noticed the boost only got to 9, stock on my model is 13. I cannot figure out why its not hitting that. Any suggestions
    Registered User benson156's Avatar
    Sep 2008
    Utah
    Any mods?? Listing them will get you a quicker response in the future.
    Hawk-eye Alliance #156
    Aug 2010
    jacksonville.FL
    Quote Originally Posted by benson156 View Post
    Yes I apologize, was not even thinking about it. aftermarket K&N AF. 3.5" Catback and aftermarket blow off valve.
    What units are you talking about? 9 what? What units does the boost gauge say it's measuring (the units will be printed on the face of the gauge).
    Aug 2010
    jacksonville.FL
    goes as fallows... line line line line .5 line line line line .1 line line line line .15, its the factory boost gauge
    Registered User Skreekin's Avatar
    May 2005
    Bellingham, WA
    Assuming you're talking about psi, your WRX won't make full boost until 3rd and 4th gear.
    Some advice too, find the OEM recirc valve and get rid of the BOV. It's just a noise maker and can cause your car to run rich.
    2005 WRB WRX Stage 2
    Blobeye Syndicate #76
    A Must Read http://www.clubwrx.net/forums/engine...do-not-do.html
    Aug 2010
    jacksonville.FL
    Quote Originally Posted by Skreekin View Post
    Getting rid of the BOV was one option, I know it causes me to loose power but I didnt blame it for not hitting 13 psi. I have had the peddle to the floor and have not seen 13psi. Im starting to think there may be damage somewhere? or possibly need to replace the factory turbo?
    Apr 2004
    Southeastern PA
    Agreed. I'd consider the BOV first. The OEM is the best choice.
    Mods & Pics
    Aug 2010
    jacksonville.FL
    Quote Originally Posted by Sasquatch View Post
    I think I may try that and see where I am at
    Quote Originally Posted by TurboTransport0 View Post
    That is not in PSI. (In fact, it shouldn't be... this is IMO but non-SI units need to meet their end ASAP -- but that's another story).
    Anyway: There is nothing in your posts that has indicated something wrong with your boost pressure. The stock gauge is in Pa. For info on the Pa (it's 1 N per square m).
    http://en.wikipedia.org/wiki/HPa
    The BOV is kitsch but it is not affecting your boost max. In fact, I doubt anything is.
    Apr 2004
    Southeastern PA
    Check all of the IC hoses and be sure there are no leaks as well. My OEM BOV performs well at 20 psi of boost.
    A handy link: http://www.onlineconversion.com/pressure.htm
    Mods & Pics
    Stock Boost Gauge
    So .9 MPa pressure is equivalent to... the car seems fine.
    Aug 2010
    jacksonville.FL
    Thats exactly what I was looking for!!! First subaru ever bought and the different measurement through me for a loop. there will be no effect if I buy a gauge in PSI will there?
    Not to the car unless you somehow generate a leak when swapping the gauges. A little piece of my soul will be hurt though, as you'll be regressing to a non-standard unit...
    EDIT: In fact, I could swear the company, Omori, made gauges that match the OEM dash and fit in the OEM gauge "cup." They were coin and I don't know what vendors might still carry them. They did match very well though - or, for much less money, other gauge brands are widely available. Check out the club's vendors if you like.
    Aug 2010
    jacksonville.FL
    Hahaha so you think I should keep it? I like the position and gauge itself, its just being a honda owner for years I never seen mPa.
