front diff fluid change?
Results 1 to 14 of 14
This is a discussion on front diff fluid change? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; i was wondering if i should change the fluid in the front differential of my 2005 wrx wagon and if ...
    Aug 2010
    Indianapolis
    i was wondering if i should change the fluid in the front differential of my 2005 wrx wagon and if it would be the same as doing the rear. the car is stock and just a daily driver. i just ordered fluid for the tranny and rear diff but wasn't sure about the front.
    also i was thinking about getting a tune up and i believe the basics to do is change the spark plugs and fuel filter but i think i read the fuel filter is in the gas tank on the 05's. is this correct? if so its not something i'm wanting to do myself.
    thanks for helping.
    The 5spd gearbox does not use separate fluids for the front diff and the gearbox itself. On these one only changes the fluid for the gearbox (use a 75W-90 GL5). The rear diff has the same fluid specification requirements.
    If your car is automatic check the manual for what to do, sorry.
    Aug 2010
    Indianapolis
    i bought red line 75w90 ns for the transmission and red line 75w90 for the rear differential but my question is should i also replace the fluid in the front and is the process for replacing the fluid the same as it is with the rear.
    2005 Subaru Impreza WRX Wagon
    Registered User ZeeTwentyEight's Avatar
    Aug 2010
    Ogden, Utah
    Quote Originally Posted by auceny View Post
    There somewhat the same, you know where the dip stick is for the the front gearbox right? you have to fill the gearbox from that hole for the dip stick.
    The drain plug is like a 17 mm hex head (i think)
    Aug 2010
    Indianapolis
    i'm not sure where the dip stick is but i'll be sure to find it. i haven't been too concerned with scheduled maintenance until i just bought a house and have a garage to work in.
    Aug 2010
    Ogden, Utah
    This is on a non turbo but almost all subbie's are the same.
    just scroll down a bit, this is also a view from the passenger side of the hood
    http://www.subaruforester.org/vbulle...in-plug-64112/
    Jul 2004
    Seattle, WA
    The front diff is inside the transmission case.
    Here's the thread you need for changing the fluid.
    DIY: Transmission Fluid Change
    05+ WRX's have the fuel filter in the gas tank. The filter does not need to be replaced unless the fuel pump has gone bad. Subaru doesn't sell the filter by it self.
    Sparkplugs
    http://forums.nasioc.com/forums/showthread.php?t=518633
    http://www.scoobymods.com/spark-plug...&threadid=3017
    Last edited by SeattleJeremy; 08-12-2010 at 12:07 PM. Reason: Adding the part about the fuel filter.
    Aug 2010
    Indianapolis
    so when i change the fluid in the transmission i am also changing the front diff fluid as the same time since it is inside the transmission?
    Moderator Donkey's Avatar
    Da boonies,Va
    Yes,if it is a manual transmission.
    2002 FORESTER S
    1998 FORESTER S
    Jul 2004
    Seattle, WA
    +1
    This ain't no Wrangler
    Aug 2010
    Indianapolis
    Smile
    thanks for the help everyone. this weekends project is new brake pads. next will be tranny and diff fluid swap since its still in the mail. after that will probably be spark plugs. the only thing that has really been done is oil changes since it was bought in 2005 so i know all of this stuff is due. anything important that i'm missing that isn't too difficult? i flushed the radiator last weekend.
    Jul 2004
    Seattle, WA
    Here's the Schedule you should be following.
    http://www.subaru.com/content/downlo...005SchedCA.pdf
    It's likely time to have the brake fluid changed as well (every 30k miles)
    Sep 2015
    NE, ohio
    is this the same with an 08 wrx?
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Quote Originally Posted by Jrsierra11 View Post
    Yes.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
