Car is only reading 10psi?
Results 1 to 3 of 3
This is a discussion on Car is only reading 10psi? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have a 2002 wrx and it is completely stock. I removed the intake exhaust box in the fender because ...
    Registered User mar1183's Avatar
    Jul 2010
    Delaware
    I have a 2002 wrx and it is completely stock. I removed the intake exhaust box in the fender because I ordered a intake system. I was measuring boost 4th gear today and it only went to 10psi. Im using an autometer boost gauge. The line is tapped into bpv on the tmic. What is wrong what should I do?
    Registered User JovicA's Avatar
    May 2010
    Denver CO
    Im no suba guru but i would try and look for some leaks or try putting all the stuff back. Then messure the boost you might just need a retune or something like that. You might have just messed up the A/F ratio or something. Im sure someone here will know and make me look like a noob anyway GOOD LUCK with fixin it.
    -Joe-
    Jul 2010
    Delaware
    I guess I will start by checking for leaks. Im not going to put the new intake on untill I figure out what the problem is. Oh and the intake I bought is from perrin, will I need to have the car tuned for that?
