Urgent help needed with power loss!!
Results 1 to 9 of 9
This is a discussion on Urgent help needed with power loss!! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hi all, I have had afew pointers on other forums but I need to get the best all round concensus ...
    Registered User scooby72's Avatar
    Jun 2010
    Dorset England
    Hi all,
    I have had afew pointers on other forums but I need to get the best all round concensus of opinion as I have lttle time to tinker at the mo and need the scoob for runs to and from hospital (poorly parents).
    The car is driving nicely but there is no urgency to it.
    The boost is at 0 bar at around 3k revs and achieve max boost 1.1-1.2 not until 4k - 4.5k revs.
    This does not feel right at all and there is no feeling of being pushed into your seat as there should be.
    This in itself is not a prob for getting about but Im sure that something is starting to fail and concerned that there could be dire probs if it does.
    Its been suggested that maybe the fins on the hot side of the turbo are now getting worn??
    Or poss a crack around the actuator valve in the casing?
    There has always been a slight vibration sound when spooling up but this is intermittant and I could feel no shaft play when probing from the intake side.
    Hope to get the car to an independant scooby tuner today maybe - but all opinions would be most welcome.
    She is getting on a little now JDM MY95 WRX classic pre facelift with the TD05 top entry turbo.
    Thanks.
    Baggers.
    Nov 2009
    Look for vacuum leaks.
    Jun 2010
    Dorset England
    Have checked all the vac hoses and can see nothing obvious.
    In now attempting to adjust the actuator to see if its the wastegate as am getting a lot of flutter.
    Any other thoughts??
    Thanks.
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    When was the last time you changed the spark plugs? When did it last have a tune up? How many miles? When was the Air filter replaced? Is your car all stock?
    If you are hitting 1.1 bar your boost seems fine.
    Maybe a CAT is plugged or close to it. If it was it would take more work from the engine to push past the restriction which is why boost comes on later and it doesn't feel fast.
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
    Jun 2010
    Dorset England
    Have now adjusted the actuator and rechecked/.tightenned all boost a vac hoses.
    I have no CAT - The filter is brand new APEXI.
    New Plugs and uprate coilpacks 6 mnths ago -the car is my weekend and holliday driver.
    Is due and oil change now admitted.
    Car has:
    Fujisu Chip (the ones polar performance and prodrive use)
    Turbo back straight through exhaust.
    Walbro fuel pump.
    Apexi panel filter.
    X-Spec coils.
    Standard NGK plugs.
    Run on 99 ron fuel.
    Forge Dump Valve.
    Some silicone hosing.
    Prob seems to have occurred recently. - IThink its the turbo getting old.
    In the Uk Andy forrest does a reworked TD05 - I think Im gonna have to get one asap.
    Will try all suggestions though!
    Jun 2006
    Nor Cal
    How many KMs/miles on the turbo?
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
    Jun 2010
    Dorset England
    pretty sure its still the original blower so that'll be 121k kilometers.
    Have just been out for a test and seems a little better after tightening the hose clamps and adjusting the actuator - boost is coming on a bit quicker so my guess is that the wastegate was openning under too little pressure - this should get me by until I can can another td05 on the old girl -what U think chap??
    Jun 2006
    Nor Cal
    Turbos start to go at around 75k-90k (120k-144k kms) miles at elevated boost levels and duty cycles here in the US. Not to mention maintenance and driving style also factors in turbo longevity. So it could be goin out.
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
    Jun 2010
    Dorset England
    Yeah same for most blowers I think - Cant hurt to get another slapped on - The engine on my classic seems to be a good one and has given me know hassle over the 4 years Ive had it.
    Shame the other two that I recently broke had no turbos on them!
    Hey ho - time to pull out the plastic I think!
    Cheers.
