Looking Some Advice pls
Results 1 to 3 of 3
This is a discussion on Looking Some Advice pls within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hi everyone, im new here and was hoping to get some help. I have a 2004 subaru wrx sti thats ...
    Aug 2010
    Hi everyone, im new here and was hoping to get some help. I have a 2004 subaru wrx sti thats been making clunking noises when i turn corners which gets worse when full lock is on, also when im driving it tends to pull to one side then to other and feels quite shaky to drive at times. I seen a mechanic who told me i needed a new front drive shaft, he is not sure which side! This alone is going to cost me £300.. I looked on eBay and found a brand new drive shaft for a 2008 sti for a fraction of the price... Now im left unsure if a 2008 drive shaft with fit onto a 2004 sti? Many thanks in advance if anyone can help me on this one..
    Registered User wrx1234's Avatar
    Sep 2009
    Dover DE
    Have you hit a curb or a large pot hole ever? To me it sounds like a wheel bearing might have busted. Does it do it when you turn in both dirrections or just one? is it louder in either dirrection?
    I had a car that i ran a curb over one time and when i turned left and the weight shifted to the right it would make a wierd vibrating noise... it ended up being the bearings on the right fron wheel.
    Did the mechanic put your car on a lift or pull the wheels off and take a look? He might be pulling your leg knowing you might just need 1 $10 bearing.
    You should be able to check this out your self by pulling off both front wheels pulling the brake calipers off taking the cap off the brake rotors removing the pin that holds the bolt on the spindel (most cars have this set up not sure about yours). Unscrew the bolts take your bearing out clean them with some brake cleaner and inspect them. make sure when you put them back in you pack the with some high temp grease. By nspecting this your self you will only be out 4-5 bucks for the grease.
    Here is a post you can check out about pulling rotors.
    Brake Rotor Replacement
    Oct 2005
    Late Devonian
    Bearings are pressed in - not coming out to be serviced. Bearing service is $$
    Check your differential fluid and search for threads describing differential issues - it sounds like that is a more likely explanation than a drive shaft.
