1998 sti - blown head gasket*help..
Results 1 to 10 of 10
This is a discussion on 1998 sti - blown head gasket*help.. within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; 1998 WRX STI - Possible blown head gasket? 5days ago car started to overheat....water was low (coolanbt/radiator).....No leaks....paid for a ...
    Aug 2010
    Te Atatu, New Zealand, New Zealand
    Unhappy 1998 sti - blown head gasket*help..
    5days ago car started to overheat....water was low (coolanbt/radiator).....No leaks....paid for a new radiator cap..but problem was still there T-stat going all over......
    2days ago I got...
    Thermostat replaced, with genuine t-stat..
    Radiator was pulled out and cleaned/checked... 20% blockage.....
    TK test done ......came back clear
    Picked up car.....and then travelling back from picking up huby...thermostat crazy again...
    Engine sounds absolutely norm...is there anything else I can check to detect blown head gasket......
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    is there oil/water mixing in the oil pan?
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
    Aug 2010
    where is the oil pan....?
    I read a couple of the other threads...they were quoted to check dipstick....for greyish colour....which suggested water was getting into to oil......But the dipstick was norm.... coolant is still in radiator.....
    Nov 2006
    Denver Metro Area
    Change your oil... The dipstick test isn't going to let you see the full picture. When you change your oil you should see whether or not the old oil is milky.
    How's your coolant level now?
    Kevin
    Moderator
    WRX Gas Mileage FAQ
    Aug 2010
    Coolant level is normal....and that was after running the car for a half hour this morning....I just noticed the fans aren't going
    Nov 2006
    Denver Metro Area
    check the fuse box. Some times the biggest problems are the simplest things!
    Otherwise the relay might be blown
    Kevin
    Moderator
    WRX Gas Mileage FAQ
    Aug 2010
    [QUOTE=Sinister;2650996]check the fuse box. Some times the biggest problems are the simplest things!
    Otherwise the relay might be blown[/QUOTE
    what am I checking for in the fuse box...
    Aug 2010
    Gonna get a leak down test down on the car this coming wednesday......and go from there ..
    Nov 2006
    Denver Metro Area
    Quote Originally Posted by CNTCM3 View Post
    A blown fuse
    Kevin
    Moderator
    WRX Gas Mileage FAQ
    Jan 2005
    Eh, whaaaaa?
    A blown fuse
    Specifically the one for the fans. Check on the back of the fuse box cover, it should show you a diagram of which one is for the cooling fans, pull it out, if it's blown (center metal ring shaped like an "s" is no longer connected, black char marks), replace it.
    Cody
