antifreeze leak
Results 1 to 6 of 6
This is a discussion on antifreeze leak within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; ok here is my problem. I have a antifreeze leak but heres the catch. hoses are good, water pump isn't ...
    Jul 2010
    antifreeze leak
    ok here is my problem. I have a antifreeze leak but heres the catch. hoses are good, water pump isn't leaking but i have a stream on the top of the rad and the bottom of the car is wet? car is running around the same temp. this crap is starting to piss me off any help would be great.
    i let the car run and i still cant find anything. on the driverside of the hood i have a wet spot about were the fan is? like i said no hoses are leaking. i checked everything and i'm lost for words. like i said the car is not over heating!!!!
    thanks
    ken.
    Not much to offer beyond "find the leak and fix it" but the radiator itself is a common source of leaks. Have you been unable to find any residue anywhere? The rad cap seams typically fail. Also, there has been a TSB for the top hose where it meets the rad inlet, but that's much less common than the rad.
    Jul 2004
    Seattle, WA
    Like SD_GR said, the radiator on WRX's are prone to failure at the plastic endcaps.
    Jul 2010
    Thanks guys for all of the help.
    do you guys know anybody or anyplace that sale a rad. used or new.
    Jul 2004
    Seattle, WA
    Only buy new. Do not buy a replacement rad with plastic end caps.
    Mishimoto and Koyo make all aluminum replacement radiators that run $250-400.
    Edit: Here's a link to Gruppe-S's website scroll down to the "COOLING" section and it's the second item for only $255.
    http://www.gruppe-s.com/Subaru/subeng.htm
    I've purchased parts from Gruppe-s before, they are a great vendor.
    Jul 2010
    thanks jeremy96gase i will check them out.
