99 impreza check engine light
Results 1 to 8 of 8
This is a discussion on 99 impreza check engine light within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; hi i'm new in here mu car has the check engine and i can;t drive at all the car stay ...
    Aug 2010
    hi i'm new in here
    mu car has the check engine and i can;t drive at all the car stay in 800 rpm if i press the gas it go to 600rpm
    i take to check what wrong with it and it 5 code
    p0500 speed sensor front
    p1540 speed sensor back
    p1101 neutral switch
    p1121 neutral switch high input
    p0130 O2 sensor open circuit front
    well i don't thing all this is no working it may be something can affect all this
    but i need other people opinion
    my car is 99 subaru impreza sedan 2.2l automatic trans
    if any body can help
    thank you
    Aug 2008
    Kennett Square, Pennsylvania
    How many miles are on the vehicle? How long has the CEL been illuminated before you pulled the codes? I'm thinking you may have a harness pinched or something, check all the connectors at the bell housing and make sure no pins have backed out or the connecter is not loose. Are you having any other problems with the car? What happens if the vehicle is in park and you try and bring the RPM's up to like 3k and hold it there, will it perform normally? Are they symptoms you are describing only happen when the vehicle is in gear?
    Aug 2010
    141890 miles
    the rpm stay 800 in park and in gear
    but if you press many times the gas pedal the rpm go up
    when go back down came back to 800 rpm
    Aug 2010
    car in parked one year
    i don't remenber how long was the cel
    the only thing i know is one day didn't more
    Aug 2008
    Quote Originally Posted by revolution View Post
    Was there anything wrong with the vehicle when it was parked over a year ago? My bet is perhaps something chewed threw the wiring or something, If none of these problems where present a year ago when the vehicle was parked and now they all appeared at once...
    Registered User devik's Avatar
    Jun 2006
    PHX Metro
    Agreed, it sounds like something happened to it while it was parked, most likely an issue with wiring or the ECU. I can't imagine how these codes would all be thrown at the same time otherwise.
    2002 Silver Bugeye WRX - Bugeye Mafia #327
    "Stage 2" + STI TMIC
    Aug 2010
    the codes show before i park the car
    Aug 2010
    the only thing remember one the i start and the rpm stay 800 i don't know what happen
