Squealing Sound
Results 1 to 8 of 8
This is a discussion on Squealing Sound within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have a 2002 wrx with 165,000 miles and when driving with the window open I hear a squealing sound, ...
    Jul 2010
    Squealing Sound
    I have a 2002 wrx with 165,000 miles and when driving with the window open I hear a squealing sound, mostly when going straight or turning right. I do not hear it when turning left. Could it be the bearings? Had them replaced through warranty at 48,000 miles in 2003.
    Jan 2005
    Eh, whaaaaa?
    What kind of squeeling sound and where is it coming from? Describe the sound as best you can please.
    Could be wheel bearings, they're a known problem with WRX's. People should consider themselves lucky to see 100k out of their originals.
    Cody
    Registered User cjm1991's Avatar
    Jun 2009
    st louis
    I have the same exact problem. Im about to replace my e brake pads and wheel bearings. I have 150k miles on my 02. Did it start right after swapping rotors and pads?
    Chris
    02 Camaro z28 T-Tops, m6 49k miles
    Bolt ons and tuned - 349rwhp/362rwtq
    02 Ws6 T-Top,m6 80k miles
    Bolt ons/Cam/tune - 436rwhp/424rwtq
    Jul 2010
    The sound is a high pitch squeal that I hear only when the window is open but it is very obvious. I do not hear it as much when going higher speeds but that may be because of the other sounds on the road. I very rarely hear it when making left turns and it usually starts after making a right turn.
    My brakes are just about due also. The last time was 92,000 miles.
    Jun 2009
    st louis
    Same thing here to the last detail... and I thought I was all alone. My dad tells me its either my ebrake pads or the wheel bearing. Ive disassemled the brakes and lubed everything... still its there. Starts at about 25-30 and is then squeals till about 40.
    Chris
    Registered User d_Ziggy_2000's Avatar
    Jun 2010
    Seattle(ish)
    What does it sound like for the wheel barings goin out? I kind of hear a clicking sound... almost as if there is a rock in the tire when at low speeds in the front left wheel... im at 130,000 miles and that caught my attn. When you said that
    '88 Sub Justy *Rock in oil pan killed on freeway
    '87 Honda Civic *Bad pistons (to lazy to fix)
    '85 Nissan 200sx *Blown engine drifting
    '00 Sub Outback *Mother literally stole
    '92 Toyota Tercel *Hated it
    '02 WRX '07 kawasaki ninja. * current
    Jan 2005
    Eh, whaaaaa?
    Easiest way to check if the wheel bearing is going bad, jack the end of the car up that is to be inspected. Secure it on jack stands. Grab the wheel on the top and bottom, and try to move either end away from the car. If there is play in there, your wheel bearing is likely bad.
    For reference:
    http://www.youtube.com/watch?v=MQhy_-9BQkc
    Cody
    Jun 2010
    Seattle(ish)
    i'll try that one tomorrow... as its 1am and i'm bout to pass out haha
