There isn't a whole lot of variables. My guess would be the oil feed line as it is the only thing pressurized.
This is a discussion on Something leaking near turbo? W/Pics Help! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; What up fellas? I am new to this forum and looking for some advice. I have a 2005 saab 92x ...
What up fellas? I am new to this forum and looking for some advice. I have a 2005 saab 92x aero 2.0L with 125,000 on it. For those who are wondering why I am posting on this forum with a saab is infact this car has the subaru wrx motor in it. Ok with that cleared up onto the problem. I just did an oil change on the car and after 2 days I notice smoke coming from the hood with a funky smell. I lifted the hood and it was coming from where the turbo is. So after reasearching this thread I pulled off the heat shield to look for a leak. I see a small amout of oil on the heat shield and this white stuff that looks like something has been burning (please see pics). Anyone have any ideas of where my leak is coming from? This is not the first oil change that I have done on this car but it is the first time I have seen or smelled the smoke. 1 pic is from the top and 2 from the bottom. Thanks in advance!
PS wasnt sure how to put the pics in the post sorry
Mike
Looks to me like the downpipe to turbo gasket is leaking. Why it is leaking something white is beyond me. Perhaps the center housing on the turbo gave up the ghost. Are you getting white smoke out the tailpipe?
+1 on the dp gasket... for the stain (I think its been there for a while)
I also think you spilled some oil on the crack case and thats what burned... causing the smoke.
**__The Hawk-Eye Alliance__**
Member #0135
Hey thanks alot guys for the response's! After looking at this other thread from NASIOC it sounds like it might just be an additive that I added to the gas. I did recently run a can of seafoam through her. Although it sure looks like the gasket going to the downpipe is leaking though. I am trying to find a vf39 with sti up and down pipe and tmic so when I do I will do those gaskets.
If any of the banjo bolts for the oil feed or drain are leaking what should I do replace the bolt or just tighten it up? Reason I ask is that it looks like the banjo on the bottom is wet and possibly leaking very slowly. I am wondering if this little leak is the reason why the car seems to go through oil? How often do you guys need to top of your oil? To me it seems like the car goes through alot of oil and coolant but then I was told that it was probably because of the turbo. Does that make sense?
