need help quick, lots of grinding and wont go in gear
Results 1 to 15 of 17
This is a discussion on need help quick, lots of grinding and wont go in gear within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Okay people I was at the street fights lastnight and I had my 02 wrx at the line and I ...
    Jul 2010
    abingdon, Va
    Question need help quick, lots of grinding and wont go in gear
    Okay people I was at the street fights lastnight and I had my 02 wrx at the line and I went to pull out at about 5000rpms and it threw itself in neutral with a lot of weird grinding but the pedal is fine but the shifter barely moves back and forth in neutral and won't go in gear its like its locked, we finally got it in second gear and tried to drive it and it grinds when your rolling with the clutch in or out now the shifter is stuck in second but the car is in neutral someone please help!
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    Congratulations, you destroyed your transmission. You just learned a $4000 lesson.
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
    May 2010
    Pittsburgh, PA
    Sorry to hear =(.
    Dragging these cars is always a risk. It's hard to do correctly, and is very hard on the tranny.
    2011 STi Build Log
  5. #4
    Administrator
    May 2003
    That's an easy one. It just popped the gear set out of synch. Put in in reverse and do another 5000rmp clutch dump. It will pop her right back in!
    Nah, just kidding. You totally grenaded your trans. Time to bust open the piggy back. Racing is an expensive hobby!
  6. #5
    It sounds much worse than a shift fork because of the problems moving the shifter anywhere at all and the noise.
    See if you can find someone with a similar car to yours that's had a worse night and wrecked it, and buy their used transmission. Swap it into yours and don't launch the car on tarmac any more.
    - Al Stewart
  7. #6
    Registered User Skreekin's Avatar
    May 2005
    Bellingham, WA
    Expensive lesson. Ouch. And to think I was mad that I spilled paint in my car. Go get a new tranny.
  8. #7
    Palmyra, NJ
    YOUR
  9. #8
    Registered User 2ndSuby's Avatar
    Feb 2009
    Bloomington IN
    Awww
    Wanna sell it ?
  10. #9
    Jan 2005
    Eh, whaaaaa?
    Another street racing idiot gets what's coming to him. Fantastic.
    Sucks man, but you did it to yourself.
    Cody
  11. #10
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    a 5000 RPM hard launch on a 2002 WRX? and you wonder what happened to your transmission?
    Sorry man, but
    $4000 + a rebuilt transmission casing will buy you a pretty solid straight-cut PPG box, so you can launch like an idiot and get away with it. Might want to start saving... or buy a Honda
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
  12. #11
    Registered User 2.0Rs's Avatar
    Jul 2007
    King of Prussia, Pa
    I have an 03 that I just put an updated 3-4 gear, hub, and sleeve in. If you want new syncros put in I can do that too at your cost in parts and maybe a couple dollars. Let me know.
  13. #12
    Oct 2005
    Late Devonian
    Quote Originally Posted by Anub1s View Post
    Interestingly, he lives just a few miles from Bristol Motor Speedway where they held the street fights event 7/22.
    Please try to be helpful everybody.
    OP - you need a new transmission, sorry for your bad luck at the strip.
  14. #13
    Registered User W甔a行iction's Avatar
    Jan 2008
    B'Ham, AL.
    Been there, Done that. Your about to find out why they nick-named the tranny's "Glass Transmissions" Although the grip is absolutely incredible in the WRX the alloys weren't up to the torque that the engine supplied. After all was said and done I went with the '04 tranny. Haven't had any problems since. If you must drive it like that you may want to invest in the 6-speed swap. It's costly but worth it. Sorry man, alot of people have been burned by this problem. I was. Set me back about $1200 for the used tranny on Ebay. I consider myself lucky. Oh,by the way, I snapped the main shaft in half while in third gear with the boost turned up. So it really doesn't take much to trash em'
    '03 WRX (Blue) COBB AP Stage 2 SPT Intake TBE
    Blitz BOV / 17" Enkie RSV's (Gold)
    ProDrive Coilovers and much more to come...
    ________________________________________________
    At first I thought "Cute Hood Scoop"Then I drove it. I've been addicted ever since.
  15. #14
    Jul 2007
    King of Prussia, Pa
    Quote Originally Posted by W甔a行iction View Post
    That gear was damaged long before you broke it.
  16. #15
    Jan 2008
    B'Ham, AL.
    Quote Originally Posted by 2.0Rs View Post
    My thoughts exactly...Just had no proof.
    Attachment 89228
    Attachment 89229
