A/C hose blew and im burning up
Results 1 to 11 of 11
This is a discussion on A/C hose blew and im burning up within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Driving uphill going through the oregon desert an my a/c's main high pressure hose blew... im going to west wyoming ...
    Registered User d_Ziggy_2000's Avatar
    Jun 2010
    Seattle(ish)
    Driving uphill going through the oregon desert an my a/c's main high pressure hose blew... im going to west wyoming (jackson hole) and i need to get it repaired and recharged ASAP... anyone have any idea or suggestions for me? Im on a budget a im on vacation
    '88 Sub Justy *Rock in oil pan killed on freeway
    '87 Honda Civic *Bad pistons (to lazy to fix)
    '85 Nissan 200sx *Blown engine drifting
    '00 Sub Outback *Mother literally stole
    '92 Toyota Tercel *Hated it
    '02 WRX '07 kawasaki ninja. * current
    Aug 2008
    Kennett Square, Pennsylvania
    Well believe it or not a leaking AC high side line ( the line that connects the condenser to the compressor) is somewhat of a common occurrence on Subarus in general, most dealerships (at least the one I work at out here in PA ) stock the high side hoses, on most Subarus its a 12mm bolt both at the compressor and the condenser... If your 100% sure that there is no r134 left in the system pop the line off, install the new one, and just pay a shop to recharge for you...How do you know the high side line is the culprit?
    Jun 2010
    Seattle(ish)
    There is a large hole in the side of it and the entire top inside of the engine was green but no other line was green at all... i know for sure that is the problem... dont the lines have to be vaccumed? Or did i read that about something else?
    The hose is easy to find. The system will have been exposed to atmosphere since you're replacing the hose, so you will need to have someone pull a vacuum for a while before recharging.
    Jun 2010
    Seattle(ish)
    What kind of places will do that though? Dealerships charge outragous amounts and id rather not do that
    Any A/C repair shop will do it correctly.
    Registered User redwrx04's Avatar
    Nov 2008
    Santa Fe, NM
    I went without a ac all summer tell yesterday, i didn't want to pay 250 bucks for a new line so i took it to a local guy who repairs them. He brazed aluminum over the part were my old top mount had rubbed a hole in the line for 15 bucks! I got it pressure tested and recharged and it works perfect!!! I would say if you think it's repairable like that, call around and find someone.
    Good luck i know it sucks!
    Blobeye Syndicate #505
    Jun 2010
    Seattle(ish)
    He recharged it and all for 15?! That does help actually! Haha hopefully there are people that can do it in the middle of wyoming
    A hose place can use metal to eliminate the area of the existing hose that has a hole in it, for very little money. You will then have a hose that holds pressure for now -- with two extra fittings where metal meets rubber and knowing that the hose failed once already.
    You will then have to re-fit the hose and as said above find an A/C shop to pull a vacuum and recharge the system.
    Jun 2010
    Seattle(ish)
    So i decided to bear it because the hose is rediculously expensive and nothing really seems to be out here... hmm... mythbusters proved duct tape is amazingly strong... lmao
    Aug 2008
    Quote Originally Posted by d_Ziggy_2000 View Post
