Driving with P0172
Results 1 to 4 of 4
This is a discussion on Driving with P0172 within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So how dumb is it to drive around with P0172 System Too Rich (Bank 1)? I got the code after ...
    Registered User wo^tron's Avatar
    Jun 2010
    Naples, FL
    Driving with P0172
    So how dumb is it to drive around with P0172 System Too Rich (Bank 1)? I got the code after putting a new engine harness on, and I reckon I messed something up installing the harness unless the dealership gave me the wrong harness...
    <ADD>
    I've kind of been suspicious of it because the injector plugs were ass backwards, but everything else hooked up just fine, I went and had my friend solder and rotate them. The dealer said it was the (revised) harness for an 04 STi though.
    </ADD>
    I just wanted to know how safe it is to drive around to work and what not a day here and there with that code? I'm not planning a cross country trip or anything like that
    Put aside the everyday world and come with us
    Into the realm of imagination
    The middle ground between light and shadow
    Aug 2008
    Kennett Square, Pennsylvania
    Well, Personally I would rather have a P0172 (system rich) that a P0171 (system lean)..This is a difficult question to answer fore you dont know the exact problem with the vehicle. Personally if the vehicle sounds ok and doesnt show any signs of problems I would drive it ( no guarantees something couldnt go wrong though )...Do you have the ability to view fuel trims and ECU data? , What happens if you clear the code...does the CEL illuminate immediately again? How many miles are on the vehicle?
    PO172 and PO171 are troubleshot much the same way. You're looking for a vacuum or boost leak, a fuel pressure regulator that's not connected well, or a metering problem. I'd park and fix it if possible.
    Jun 2010
    Naples, FL
    Yeah I've gone and cleared the code but at idle it will bog down and the CEL will come back. Driving it's fine. I only get a little bit of black smoke at idle when I rev it or it starts up real rich and has a hard time venting it also mists from time to time like when my upstream o2 sensor was going. I have a tactrix cable but it doesnt want to connect to romraider anymore
    (Keep in mind everything tune wise was perfect before I put the harness on)
    When I get a minute I'm going to go trouble shoot it. I read somewhere that system too rich causes the AFRs to drop around 35%. So I reckon I idle in the 9's since thats when its boggy. Like something is wrong with the intial startup, when i turn the car on it kinda sputters a bit until the RPMs build up and the fuel clears out. I think I just didn't put something together right or kinked a fuel line or something dumb like that.
    The car has around 57,000 miles on it with a 255lph walbro that probably has 20k on it. I don't know about the fuel filter though. I also have Power Enterprise 850cc injectors
