Help!! Battery light and E-Brake light on
Results 1 to 10 of 10
This is a discussion on Help!! Battery light and E-Brake light on within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I am hoping someone can help me. I recently purchased a 2002 WRX Wagon. It has 110k on it and ...
    Jun 2010
    I am hoping someone can help me. I recently purchased a 2002 WRX Wagon. It has 110k on it and runs great. About a week after I got it the E-Brake light and Battery light came on sporadically and now its not going away. I searched the other threads and found that the E-Brake light will come on if the fluid is low so I topped that off hoping it would help. No luck. The belts look like they are in good shape (no cracking or visable wear). I also read that it could be an electrical issue but the battery is new and I haven't noticed any loss of power, dimming of any lights at idle or any of the normal signs associated with the alternator going bad or a dying battery. The battery was replaced before I bought it so I don't think that is the problem. I'm new to the Subie scene and I apologize if this question has been answered in another thread. I did my due diligence and searched before posting a new thread but couldn't find anything. Hope you guys can help. Thank you.
    Registered User Price is right's Avatar
    Jul 2009
    louisville ky
    Quote Originally Posted by rusky314 View Post
    I am also slightly nubish, but i had a similar problem with the brake light periodicly comming on. about a week after it started happening, i changed my brake pads. havent had the light on since. i believe this is a subaru thing, as my moms tribeca did the same thing. new pads and it went out. as for the battery, my guess would be a short somewhere but i dont have any personal expirence with that. sorry if this doesent help.
    bugeye mafia #232
    World Rally Blue 2002 WRX Stage 2 290 awhp
    my mods
    Check the charging system. It's either the battery, the alternator, or the connections between them.
    Moderator Donkey's Avatar
    Da boonies,Va
    +1 When the battery and brake light are on its the charging system.
    2002 FORESTER S
    1998 FORESTER S
    Jun 2010
    What am I looking for when I check it? It has a new battery and I haven't had any issues with dimming lights or difficulty starting it. I'm not seeing any of the normal signs of the alternator taking a crap on me...
    Aug 2008
    Kennett Square, Pennsylvania
    do an alternator output test, you could also check the diode pattern , as mentioned the e-brake warning light and the battery light are on the same circuit I believe, have seen this problem many times on all Subarus in general, 99% of the time its the alternator....
    Da boonies,Va
    Test the voltage off the battery when the car is at idle. You should be seeing between 13.6-14.2 volts. If your seeing battery voltage (12-12.5volts) your alternator is shot.
    2002 FORESTER S
    1998 FORESTER S
    Oct 2009
    Milton
    E-brake and Battery light
    I'm getting a e-brake and emergency light issue as I accelerate? I've tested the voltage at the battery at idle and it seems fine @ 13-14Volts. I notice if I rev the engine it goes slightly over 17Volts. Is this normal? Do I have an issue with a regulator?
    Quote Originally Posted by shankster26 View Post
    I'm getting a e-brake and emergency light issue as I accelerate? I've tested the voltage at the battery at idle and it seems fine @ 13-14Volts. I notice if I rev the engine it goes slightly over 17Volts.Is this normal?
    I don't think so.
    I believe so.
    Da boonies,Va
    You need a new alternator ASAP. You should not see over 15 volts.
    2002 FORESTER S
    1998 FORESTER S
