I need help with my horns
Results 1 to 12 of 12
This is a discussion on I need help with my horns within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; i have a wrx 02.... well i just noticed that my horn doesnt work.. i think the problem is the ...
    Jul 2010
    i have a wrx 02.... well i just noticed that my horn doesnt work.. i think the problem is the harness or wiring from the relay to the horn......cuz when made my friend press the horn inside i heard a click sound in the relay....which means that the relay is getting power but its not getting power from the relay to the horn....do u guys know any other way to fix the horn....if u guys know any schematics that shows the wiring...that will be great..thank you for your time.... shootzzz
    May 2007
    behind the wheel
    Quote Originally Posted by pinoy69 View Post
    a horn is a very basic device. there's a 12V, and ground wire.
    Have you tested the wires at the horns to determine that you are indeed getting both ground and 12VDC at the horn, when the button is depressed?
    If you are, I'd replace the horns, rather than try to fix them. Replacements are very inexpensive. YOu could also use the opportunity to go with Hellas, or whatever you'd like, at that point.
    Rogan o_0
    Jul 2010
    i tried that already.....got a new horn...but still dont work..... i checked the wire going to the horn and its not getting any voltage....so i dont know.....im getting pissed at it......
    May 2007
    behind the wheel
    start tracing it back, then. I'll try to find a schematic.
    Rogan o_0
    Vez
    Vez is offline
    Registered User Vez's Avatar
    Apr 2006
    Near Philly, PA
    When I installed my Hellas, I was having the same problem. It turned out that I had pinched a wire in a blind location and the signal was arcing. Maybe it's a short?
    Hawk-Eye Alliance #081
    I'm the only person born a Pirate and trained as a Ninja; I sometimes don't get along with myself..
    2007 UGM WRX STI Ltd. #081/800
    Jul 2010
    well the line goes in the firewall......
    May 2007
    behind the wheel
    you are working on the ones in front, behind the grill, and not the one hanging on the strut tower, correct? just checkin..
    Rogan o_0
    Jul 2010
    the one im talking bout is the one on the strutbar...
    Jul 2010
    do hella horn need the stock horn wire......i still want to fix my horn still though...
    Registered User Ventura'sWRX's Avatar
    Mar 2010
    Chicago, IL
    Yes one, if you plan on using the relay which I did.
    http://i654.photobucket.com/albums/u...ella/hella.jpg
    I'm not in this world to live up to your expectations and you're not in this world to live up to mine.
    Bruce Lee
    Blobeye Syndicate Member #72
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    Sounds like a personal problem...
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
    Jul 2010
    is there any suggestion....what i should do
