problem when letting off the gas and getting back on it
Results 1 to 13 of 13
This is a discussion on problem when letting off the gas and getting back on it within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; hello i am new to this and have a problem with the car when i let off the gas and ...
    Registered User 02wrxman's Avatar
    Jul 2010
    weston vermont
    hello i am new to this and have a problem with the car when i let off the gas and then step back right on it it spuders and hasates for a sec and then its find any help would be great thank you for the help
    Registered User cjm1991's Avatar
    Jun 2009
    st louis
    Welcome, sweet bugeye What mods and how many miles.
    Chris
    02 Camaro z28 T-Tops, m6 49k miles
    Bolt ons and tuned - 349rwhp/362rwtq
    02 Ws6 T-Top,m6 80k miles
    Bolt ons/Cam/tune - 436rwhp/424rwtq
    Jul 2010
    weston vermont
    thank you and 68500 miles on it and it has intake uppipe and down pipe and exhuast thats it
    May 2007
    behind the wheel
    do you have an aftermarket BOV?
    Is your ecu stock, or do you have it remapped for the intake and such? If not, and it's running the original OEM map, then there's a problem, there.
    The mods you have are requiring a different ecu map.
    Rogan o_0
    Jul 2010
    weston vermont
    oh and it also has upgrade fule to and idk if the injectors are biger or not i cant tell i am new to this
    and thank you for the help
    Jul 2010
    weston vermont
    its stock as far as i know for the ecu and what kind of tune and were can i get one for the car
    May 2007
    behind the wheel
    Quote Originally Posted by 02wrxman View Post
    Take a read through our engine manageme threads and get a little educated on the matter, the find a reputable subaru tuner in your area. Your least expensive route will be going open-sourced tuning.
    Rogan o_0
    Jun 2009
    st louis
    You could buy a Cobb Accessport or TurboXS EcuTek. Both are piggy back with preloaded maps. Usually run around 400 used, or 600 for Cobb and 1000 for utek I believe. Or if you find a tuner near you, you could get an opensource tune. Id have someone look at it and tell you if they see aftermarket parts. Otherwise could just be a dirty maf or something easy to fix.
    Chris
    Jul 2010
    weston vermont
    they are after market cause it came with the stock exhaust in the car and it had a sensor in the uppipe that is not in the new uppipe and could that be part of the porblem it the sensor right befor the turbo adn thank you for the help
    Jun 2009
    st louis
    The catless up pipe should always be a first mod on 02-05 wrx. You dont need to plug that sensor in. If your car isnt tuned for the exhaust thats your problem. With a protune youd have no hesitation in throttle response.
    Chris
    Jul 2010
    weston vermont
    all right then ill have to put one in and or get a tune and thank you for the help i really appertet it
    Jun 2009
    st louis
    No prob
    Chris
    May 2007
    behind the wheel
    seriously look into OpenSource tuning, like ROMRAIDER. there's tons of support, and a huge chance that there's a tuner for it, close to you.
    just saying..
    Rogan o_0
