first oil change
Results 1 to 8 of 8
This is a discussion on first oil change within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hey everyone. happy to be a new member of the forum and a new subaru owner. picked up a 2010 ...
    Registered User dbya rx's Avatar
    Jul 2010
    San Marcos, California, United States
    first oil change
    Hey everyone. happy to be a new member of the forum and a new subaru owner. picked up a 2010 wrx limited, and im a few ticks off 3k miles. Want to do my first oil change. I've got a case of MOBIL 1 syth, a oem oil filter, and a new drain plug washer...is there anything else i need? anyone have any tips before i go?
    The dated receipts for your files in order to prove the maintenance was done for warranty purposes.
    Les jeux sont faits.
    Registered User armindk's Avatar
    Dec 2009
    louisville, ky
    Wait you are doing your first oil change at 3k miles? Aren't you suppose to do the first one at 500 miles?
  5. #4
    Jul 2010
    first oil change
    Quote Originally Posted by armindk View Post
    the 2010 booklet states first oil change required at 3k, and then all other changes required every 3750 miles
  6. #5
    Dec 2009
    louisville, ky
    I see. I have been used to the 500 mile oil change then the 1000 then 3000 from then on.
  7. #6
    Jul 2010
    i read on another thread that i need to pre-lube the turbo before startup...is that necessary? how do i do that?
  8. #7
    Administrator
    May 2003
    I believe that's called "overkill". As is the 3k interval oil change.
  9. #8
    Dec 2009
    louisville, ky
    Maybe it's different on a new engine than a rebuilt engine but I would like to get the metal scarping and the assembly lube left over out of the engine after 500 miles with an oil change.
