white smoke caused from turbo? - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 30 of 30
This is a discussion on white smoke caused from turbo? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; yes, you would. the turbo is water-cooled, so there could be leaking around the sealing surfaces of the water jackets. ...
    May 2007
    behind the wheel
    If it consistently smokes after no pre-shutdown idling, and consistently does NOT smoke after pre-shutdown idling, then I, too, would look at the CHRA for the culprit.
    Rogan o_0
    Supporting Member yamaha_rider619's Avatar
    Jul 2009
    colorado is home, Kansas is the temporary home
    I would not say its perfectly consistent. I will try to check the turbo this weekend.
    When i pull the dp, would i just check for wetness and check the fins on the turbo to see if they are loose?
    Josh
    2003 Subaru Wrx Vf39'd
    Bugeye mafia #300
    May 2007
    behind the wheel
    you aren't really going to be able to check it, very well. especially with it still mounted.
    look for white, chalky-looking residue on the exhaust side turbo outlet when you pull the dp.
    Start closely monitoring your coolant level in the overflow bottle. mark where it is, and check it again in a few days, noting any changes.
    Rogan o_0
  6. #19
    Jul 2009
    Well i took it to the dealer today. Oil pan was removed by previous owner and is getting resealed. i also have a leak in my pcv hose/tubing and lastly i possibly got screwed over by a local company. I will give a name after i get results of further testing of the work they did and if it is truly leaking again; they replaced the plastic separator plate with a metal one.
    Josh
    Bugeye mafia #300
  7. #20
    Jul 2009
    took 2 videos today of the problem. Doesnt smell like burning oil or coolant. dealership said pcv hose and t-piece need replaced, will do this weekend, but i dont think a leaking pcv t-piece could cause this...
    http://www.youtube.com/watch?v=61eDMVdFhrc
    http://www.youtube.com/watch?v=x7U23aKs0g0
    Josh
    Bugeye mafia #300
  8. #21
    May 2007
    behind the wheel
    http://www.youtube.com/watch?v=8ntFfklW-_s&NR=1
    a poor pcv system WILL cause it to smoke. I know for a fact, that it will.
    Rogan o_0
  9. #22
    Jul 2009
    I watched that video before i posted mine lol. it gave me hope that my fix was right around the corner, i just wanted to ask the wrx people
    Josh
    Bugeye mafia #300
  10. #23
    May 2007
    behind the wheel
    Quote Originally Posted by yamaha_rider619 View Post
    ahh LOL
    yeah, if the pcv/evac system isn't working properly, it can/will over-pressurize the crankcase, and push oil past internal seals/rings.
    Rogan o_0
  11. #24
    Jul 2009
    i just want to drive my car and it be okay lol
    Josh
    Bugeye mafia #300
  12. #25
    May 2007
    behind the wheel
    check the pcv valve, too, to make sure it's not clogged or anything.
    Rogan o_0
  13. #26
    Jul 2009
    I just put a new one in last Friday but I had no idea my hoses were leaking
    Josh
    Bugeye mafia #300
  14. #27
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    bummer dude.
    Check if it's the hoses.
    If it's not the hoses... The turbo really sounds like the culprit.
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
  15. #28
    Jul 2009
    I think it's the hoses, get them tomorrow sometime
    Josh
    Bugeye mafia #300
  16. #29
    Aug 2010
    ny
    white smoke is usually from a head gasket problem,blue smoke is from the turbo
  17. #30
    Jul 2009
    its not a head gasket, i have it checked thanks though
    Josh
    Bugeye mafia #300
