CEL codes p2444 and p2443
Page 1 of 4 1234 LastLast
Results 1 to 15 of 58
This is a discussion on CEL codes p2444 and p2443 within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; 06 WRX w/ 57k runs and drives fine, but kind of idles rough... MODS CBE stage 1 map silencer delete ...
    Feb 2010
    SL,UT
    Exclamation CEL codes p2444 and p2443
    MODS
    CBE
    stage 1 map
    silencer delete with elbow piece and K&N drop in filter
    Hawk-Eye Alliance #801
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    That's within warranty. That's part of your emissions system. Go to your dealership.
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
    Feb 2010
    SL,UT
    The guy at autozone said it could be just a dirty MAF sensor, but I don't know... do you know what it could be and if the factory powertrain warranty cover it?
    Nov 2006
    Denver Metro Area
    Quote Originally Posted by 06scoobyrex View Post
    Guy at autozone works at autozone for a reason...
    Those have to do with the air pump that was added early 2006 onto the WRX.
    It's the thing in the top right corner of your engine bay that looks like a plastic turbo.
    Kevin
    Moderator
    WRX Gas Mileage FAQ
    Nov 2006
    Denver Metro Area
    And no... that's not covered under your powertrain warranty. It's covered under the emissions warranty. 8years 80,000miles.
    Kevin
    Moderator
    WRX Gas Mileage FAQ
    Feb 2010
    SL,UT
    Ohh okay... so its just the airpump? If its an emmissions issue then I shouln't have any problems driving it, correct?
    Nov 2006
    Denver Metro Area
    meh... probably shouldn't. It may foul your catalytic converter though.
    Kevin
    Moderator
    WRX Gas Mileage FAQ
    Feb 2010
    SL,UT
    Ohh allright thank you sinister, ill take it in tommarow...
    I agree. Emissions warranty, incidentally, is very strong and absolutely should be very strong. This is why emissions components are supported for longer than one might think. Take it to your dealer and have them fix it under the emissions warranty.
    Feb 2010
    SL,UT
    Would they deny it for any reason due to my reflash?
    Nov 2006
    Denver Metro Area
    you're stage one. Flash to factory and keep the cobb at home.
    It's always good to cover your ass.
    Kevin
    Moderator
    WRX Gas Mileage FAQ
    Nov 2006
    Denver Metro Area
    not a bad idea.
    Kevin
    Moderator
    WRX Gas Mileage FAQ
    Feb 2010
    SL,UT
    I don't have an AP, its an open scource map.... would they really look to see if its been flashed for an emmissions issue?
    Nov 2006
    Denver Metro Area
    The problem is... they may try and reflash your car to an updated firmware if there is any. Which would overwrite your current flash.
    I highly doubt that they'd deny you warranty on the emissions components from your flash.
    More than likely this will be a hardware issue, not software. But if it's software, then they could charge you because of the flash.
    Kevin
    Moderator
    WRX Gas Mileage FAQ
    Feb 2010
    SL,UT
    update...
    I called the dealership and they said that it would be covered under the emissions warranty if it were registered in california, but I'm in utah so they said it wouldn't be covered...
