CEL codes p2444 and p2443 - Page 2
Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 58
This is a discussion on CEL codes p2444 and p2443 within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Originally Posted by 06scoobyrex update... I called the dealership and they said that it would be covered under the emissions ...
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    Quote Originally Posted by 06scoobyrex View Post
    update...
    I called the dealership and they said that it would be covered under the emissions warranty if it were registered in california, but I'm in utah so they said it wouldn't be covered...
    Wrong. Absolutely wrong. They're full of sh!t.
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
    Nov 2006
    Denver Metro Area
    do you all have a second subaru dealership in the area?
    The warranty is from subaru of america... Not subaru of california.
    Kevin
    Moderator
    WRX Gas Mileage FAQ
    Feb 2010
    SL,UT
    yeah there are 3 of them that I know here in salt lake county.
    I'll call a different dealership and play dumb to see what they say about it...
    Hawk-Eye Alliance #801
  6. #19
    Nov 2006
    Denver Metro Area
    I'd say, "I have a check engine light, and I'm under warranty. When can I make an appointment?"
    That's all you need to say.
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  7. #20
    update...
    Contact SOA and tell them letting their cars fail emissions requirements is unacceptable anywhere on the planet. Tell them the environment and our natural resources are important to you and you had believed based on their reputation that these things were important to them also.
  8. #21
    Feb 2010
    SL,UT
    update...
    i took the car in and they told me that the emissions warranty does not cover it or my extened warranty... I also contacted SOA and they told me that the coverage varries from state to state, so it looks like I have to shell out $750 for the part unless I can find a used one... Anyone have any suggestions?
    I also have to replace the relay as well...
  9. #22
    Nov 2006
    Denver Metro Area
    update...
    Yeah.. I have a suggestion. Remove the damned thing, and get blocking plates for super cheap.
    Or get in a fight with SOA. Your choice. I wouldn't take that crap. You're under the 5yr 60,000 mile warranty and the 8yr 80,000 mile emissions warranty... and they won't cover it? I'm calling b.s.
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  10. #23
    Nov 2006
    Denver Metro Area
    This^^
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  11. #24
    Feb 2010
    SL,UT
    I would like to get rid of the knuckle splitter alltogether... is it hard to remove and are the plates hard to install?
    By removing it, Will I get CEL's or have a problem with emissions?
  12. #25
    Feb 2010
    SL,UT
    Bump
  13. #26
    Feb 2010
    SL,UT
    Bump...
  14. #27
    Nov 2006
    Denver Metro Area
    They say that the driver's side, and the vacuum pump are cake. Apparently the passenger's side is close to the up pipe and will take some cursing.
    You'll get CEL's, but they can be removed via flash.
    You shouldn't have any problems with emissions... they're for startup emissions, and most emissions places shouldn't know about them
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  15. #28
    Feb 2010
    SL,UT
    Would I have to remove the ic? Where can I buy the blocking plates from?
    If I were just to remove the relay and or fuse would it prevent it from comming on at all?
  16. #29
    Nov 2006
    Denver Metro Area
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  17. #30
    Feb 2010
    SL,UT
    Thank you Sinister, I really do appreciate all your help.
    One last question, can I just remove the fuse and/or relay to turn it off (and hopefully the CEL codes)? I know I can do a hard reset on the ECU, but I don't like doing that cause it messes with my MPG's and performance...
