Could be a slipping clutch I suppose. On very open road, put it in 6th at low RPM and floor the throttle. If the tach needle jumps but the car does not accelerate, shop for a replacement clutch.
This is a discussion on Boost problem within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have a 04 WRX STi completely stock with 45k km. When i am in 3rd gear and hit 3k ...
I have a 04 WRX STi completely stock with 45k km. When i am in 3rd gear and hit 3k rpm the the turbo kicks in and rev meter quickly boosts to 5k rpm unexpectidly and jerks their a while. Anyone know why this is happening? It never use to happen before. In all the other gears the revs go up constantly at the same speed.
do you reccomend the sti clutch or another brand?
upgrade your clutch. I like my ACT. That's up to you. Use a full face organic clutch. (DON'T GET PUCKS, Ceramic/Kevlar, etc)
And don't resurface your flywheel. Subaru flywheels are disposable and not meant to be resurfaced.
Your new clutch will come with a throwout bearing.
