High idle
Results 1 to 11 of 11
This is a discussion on High idle within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; my 05' wrx is idling around 2000-2500. not to sure what that means. any advice? I just did an engine ...
    Feb 2008
    RENO, NEVADA
    High idle
    my 05' wrx is idling around 2000-2500. not to sure what that means. any advice? I just did an engine swap, the car is stock but the idling thing is now just happening after 2 weeks of driving.
    Registered User d_Ziggy_2000's Avatar
    Jun 2010
    Seattle(ish)
    What I would do is check the throttle cable.. you should be able to tighten and loosen a little nut on it... the tighter the higher the idle.. does it seem to happen more when u just start the car?
    '88 Sub Justy *Rock in oil pan killed on freeway
    '87 Honda Civic *Bad pistons (to lazy to fix)
    '85 Nissan 200sx *Blown engine drifting
    '00 Sub Outback *Mother literally stole
    '92 Toyota Tercel *Hated it
    '02 WRX '07 kawasaki ninja. * current
    Feb 2008
    RENO, NEVADA
    no it stays the same the whole time even with the ac on but i'll check the cable.
    Jun 2010
    Seattle(ish)
    Alright so that's what I would guess...
    Since you did an engine swap, I'm guessing the bracket that is holding the cable to idle is just in slightly different place so it just needs the little.. I guess its just a stopper.. to be loosened til it idles to where you like it
    Feb 2008
    RENO, NEVADA
    i will try it
    Jun 2010
    Seattle(ish)
    Cool.. keep me posted on how it goes
    Registered User W甔a行iction's Avatar
    Jan 2008
    B'Ham, AL.
    I would agree on the accel cable as well. By just simply tugging on mine or lifting it up will make it rev.
    '03 WRX (Blue) COBB AP Stage 2 SPT Intake TBE
    Blitz BOV / 17" Enkie RSV's (Gold)
    ProDrive Coilovers and much more to come...
    ________________________________________________
    At first I thought "Cute Hood Scoop"Then I drove it. I've been addicted ever since.
    Feb 2008
    RENO, NEVADA
    well i couldn't find anything wrong with the accel cable.it only starts idling high when the car sits at idle for awhile.
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    Quote Originally Posted by STANLEY722800 View Post
    that's normal. The car gets hot, and then it idles higher when the fans kick in... at least on my DBW car... I don't know about the throttle cable cars if it's able to do that.
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
    Feb 2008
    RENO, NEVADA
    ok it is still doing it. i know that the fans will kick on and the car will idle different, but at 3000 rpms. there are no codes showing up.
    Jan 2008
    B'Ham, AL.
    At one time I had a idle air control valve start acting up intermittently and never gave me a cel.
