Results 1 to 8 of 8
This is a discussion on WRX wierd grinding noise coming from rear wheels! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So my 03 wrx is having some wierd noises coming from the rear wheels...I recently re-placed my rear rotors and ...
    Jun 2008
    baltimore
    So my 03 wrx is having some wierd noises coming from the rear wheels...I recently re-placed my rear rotors and pads and I still have this funky sound going on. Also my driver side wheel is running really hot.
    Does anyone have/had this problem?
    I was thinking it might have something to do with the e-brake. When I pull the e-brake up it doesn't seem to catch all the way and my car stills rocks forward or backwards after applying the bake.
    Any help would be appreciated!
    thanks-josh
    Feb 2010
    SL,UT
    Sounds like a blown rear diff... look it over more and give more details please...
    Hawk-Eye Alliance #801
    Yes... you need engine management for engine modifications
    http://www.clubwrx.net/forums/tuning...ne-mods-6.html
    Mar 2009
    Noise and hot tires at highway speeds could just be an alignment problem. If its at low speeds maybe more serious, bearings, rack, brakes.
    Registered User GrtScott's Avatar
    Apr 2010
    Los Angeles
    Perhaps your wheel bearing has taken a dump. I just did the wheel bearings on a VW which fixed a similar problem.
    You can youtube wheel bearings and they'll have videos of what bad wheel bearing sound like.
    Jul 2004
    Seattle, WA
    Quote Originally Posted by joshuagriffin View Post
    This is a clear sign of Wheel Bearing failure.
    Replace the wheel bearing, and you should be good to go
    Last edited by SeattleJeremy; 06-22-2010 at 02:25 PM. Reason: making the first statment more clear.
    NRD
    NRD is offline
    Jun 2010
    Rialto
    is it rpm or speed related? i had a similar problem with my 02. everytime i would let off the gas i would get a grinding noise around my passenger rear wheel. it turned out to be the transfer of sound coming from my center diff, through the driveshaft, through the read diff, through my axle, and into my strut. it was trippy and i never could find out what it was until i took the tailshaft off of the trans. the cir clip fell out of the center diff and shreaded my transfer gears.
    Moderator YBNormal07's Avatar
    Jul 2003
    PA
    Run the car down the road for 10 minutes at highway speeds (on an appropriate road. Stop. Get out. Feel the center of all 4 rims. If any of them are warmer in comparison to the others, you have a wheel bearing about to go. Get it replaced now...do not wait. You will regret it.
    Also...careful when you are touching the rims...a bad wheel bearing can easily reach skin scorch temps very quickly. Don't ask me how I know.
    If this isn't the issue, do circles and listen for change in pitch to the noise. Go left, right, and straight, listening. If it changes pitch, it could be a center or rear diff.
    If this isn't the issue, check all of your retaining clips on your pads...if installed loosely or incorrectly, they or the pads could be dragging and causing the noise.
    tEh PriUs=teH faSTah!@@!
    306 AWHP/341 AWT, Stage 2
    Jun 2008
    baltimore
    Sorry for the late reply
    Thanks for all the advice. It only makes the noise when I'm turning. Seems to be more noise when I'm turning left the right.
    Also I have noticed a squealing sound when I'm driving and it stops when I apply the brakes. It doesn't do it all the time just when ever it feels like it.
    thanks again-josh
