Loud rattle and chatter noise from engine bay after hitting rev limiter. car sut down
Results 1 to 8 of 8
This is a discussion on Loud rattle and chatter noise from engine bay after hitting rev limiter. car sut down within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So i was racing some fast and the furious wanna be (and yes i won) i wasnt paying enough attention ...
    May 2010
    So i was racing some fast and the furious wanna be (and yes i won) i wasnt paying enough attention to my tach hit my rev limiter. After i heard a loud slap/rattle noise when i got on the gas. I figured it had to do with the exhaust, thats all i can relate this noise too. Then to make a long story short i was on my way home and noticed it started losing power going up the hill once o got over it and released the gas a bit she shut down and wouldnt start back up. Im thinking i killed the motor, but i honestly have NO IDEA what it could be or mean. If this has ever happend to you let me know what it was.
    04 WRX (stock-stage 1:93oct V-1)
    Sounds like a Pyrrhic victory, sorry.
    A loose exhaust is unlikely to have led the motor to shut down.
    Check the basics, including the exhaust while you are at it I suppose, but also make sure the car has no intake leaks (that you didn't pop an I/C hose, for example) and that the belts are all still there (that one didn't snap and the clanking wasn't a seized pulley etc.).
    I'm hoping you won't exclude all the basic external stuff because then there's not much left but the motor.
    The Fruit mangostick's Avatar
    Oct 2009
    VB VA .. the ghetto on the sea
    how many miles on it? .. my first thought was that the timing belt jumped a tooth... probably wont hurt to do a compression test to make sure.
    OBP 2010 5dr *traded*
    SWP 2013 FRS
    SUCH IS MANGO!
    May 2010
    it has 60,000 miles on it. See i thought it was exhaust too but i didnt think it would make the car loose power after awhile then shut down right after! im hoping its not the timing belt cause that happend on a eclipse that i use to have and that was expensive...its at a shop right now. Im gonna let them figure it out since its there then ill figure out if i have the time to fix it or not
    I can't think of how you over-revved while on the throttle, and in any case a jumped belt is less likely on the Subaru than on the Mitsu, as the Mitsu has not only the timinb belt but also a balance shaft belt under the front cover and either one will ruin your day - the Subaru only has the timing belt, and at 60K your motor is - or should be! - "new." A seized pulley would do it but hopefully it's something simpler.
    Now, you may have over-reved off throttle, as the limiter can only cut combustion, not prevent the motor from physically spinning too fast if the driveline is still engaged to it.
    May 2010
    i feel stupid asking this but this is my first subie, let alone a turbo charged car....i have never heard of a seized pulley? what is?which one would it be? and am i looking at a huge job? did it hurt motor internals?
    By "pulley" I meant any of the wheels, rims, or tensioners in the front of the motor, either visible or under the front cover, that carry a belt. Sorry but I just don't know what could be wrong at this stage, so it's a waiting game.
    May 2010
    ya i knew what u were talkin about by a pulley i just never heard of one ever seizing up...but thank you for the info. Hopefully the shop can tell me what it is on monday but ill keep yall posted with updates on this post
