low boosting
Results 1 to 15 of 23
This is a discussion on low boosting within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; My 06 wrx usually runs 19psi boost, its currently running 6 at max. Troubleshooting? Any quick fixes I pray I ...
    Registered User CRFX528's Avatar
    Feb 2010
    The tip top of..... Kentucky
    low boosting
    My 06 wrx usually runs 19psi boost, its currently running 6 at max. Troubleshooting? Any quick fixes I pray I don't need a turbo...
    06 WRX ( a work in progress )
    95 Tacoma ( Ol' Faithful )
    I'm new.... Enlighten me.
    Oct 2005
    Late Devonian
    Quote Originally Posted by CRFX528 View Post
    Probably your boost control solenoid is fubbered or the car is running in safe mode. You can search here for directions on cleaning & testing the BCS.
    Feb 2010
    if i do an ecu reset the car goes back to normal. Is that something that quickly can point out?
    Oct 2005
    Late Devonian
    Yeah, that means it is the computer not the BCS. However, why it is potentially doing that is much more complicated.
    Is it throwing any CEL codes?
    Feb 2010
    no, no CEL's. The only code that has been removed by the tuner was the Fuel trim too lean code. I do have a TurboXS BOV, and whether it could've been leaking or not i dont know but i twisted it to adjust and disconnected the battery - good to go. for now. The car like i said runs 19psi which is relativly high boost correct? Could it have gone into limp mode or something from overboost?
    I should've done one or the other but i was in a hurry.
    Oct 2005
    Late Devonian
    Oh, I'm glad you clarified.
    I would guess it had nothing to do with the ECU and was the BOV. If it is leaking you won't make boost. Luckily that means it is back to being simple again. You need to get that BOV set up just right or put the stock one back on. I don't run one but there are directions around.
    Feb 2010
    So the bov could be my whole problem? Its been on the car since april, its made it run a little rich but nothing terrible, could it have just went out of adjustment? I really appreciate your help. I'm so glad my turbo is ok!
    Registered User PRE-Erich's Avatar
    Jun 2009
    Gresham, OR
    bov could be the problem. take it apart, clean the piston, lube it with gun or sewing machine oil, make sure there are 4 washers for a 2.0L or 5 washers for a 2.5L and the long spring if your venting to atmosphere. That should fix any issue with the BOV
    as for limp mode, it's a definite possibility. You should take it back to your tuner and let him see what it's actually doing on the dyno.
    Erich Uhlman
    Performance Race Engineering - www.PREracing.com
    13339 NE Airport Way. Portland, OR 97230
    503-619-0055
    google map
    Follow Us on Twitter
    Like us on Facebook
    Feb 2010
    Are there any other things it could be? The bov seems to be adjusted correctly.
    Jun 2009
    Gresham, OR
    is there a restricter pill between the wastegate and boost source?
    Erich Uhlman
    503-619-0055
    google map
    Like us on Facebook
    Feb 2010
    The car has just recently started doing this. I've owned it since april and although its given me problems, making boost was never a problem. Its 90degrees here, could it be getting hot?
    Jan 2005
    Eh, whaaaaa?
    What are your mods and who did the tune?
    Cody
    Feb 2010
    TBE, SPT intake, stg 2 tune from Romraider i believe? a local guy did it for me. The tune has never caused an issue, what would be making it bring up one now?
    Could it have something to do with my flashing security light? flashes twice every other second since i had a new key made for it? (I searched.... and searched... and searched... NO SOLUTION)
    Jan 2005
    Eh, whaaaaa?
    Those are pretty high boost levels with just a stage 2 tune on those mods the guy would have had to have been pretty careful tuning for that. I'm wondering if your car is going into limp mode, but for some reason isn't doing it's usual christmas light display on your guage cluster.
    You don't have any way to datalog do you?
    Cody
    Feb 2010
    its sounding like a limp mode to me, because the car runs right for a while if you do an ECU reset. If it were a leak or BCS, wouldn't it run bad all the time even after an ecu reset? I do not have a way to datalog, unless it doesn't require much?
    no cel's, the only one that has been removed from the computer was the Fuel Trim too lean code because it just wouldn't go away no matter what i did.
    This is where i kick myself for buying a car that someone else modded.. sometimes i just wanna put the for sale sign in the back window.
