Maintenance questions
Results 1 to 15 of 18
This is a discussion on Maintenance questions within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I'm going to be doing an all out service on my 2003 WRX wagon since I just got it and ...
    Registered User wasisnt's Avatar
    May 2010
    WA
    I'm going to be doing an all out service on my 2003 WRX wagon since I just got it and don't know what it needs (114k miles) but I'm not sure what fluids etc that it takes. Can anyone tell me the type\weight\amounts for the following?
    Diff fluid - front and rear
    Manual trans fluid
    Brake fluid
    Coolant
    I don't even know what weight oil it takes!
    I'm also doing the plugs and fuel filter. I just had the timing belt done. Is there anything else I should consider doing?
    Thanks
    Jan 2005
    Eh, whaaaaa?
    Trans and front diff share the same fluid. 75W90, I'd recommend the Subaru fluid. But I'm running Uncle Scotty's ****tail and having success with it.
    Rear Diff: Subaru LSD fluid, though I'm running redline currently, I'd still recommend the OEM fluid, which I will be going back to.
    Brake fluid: Any Dot 3 or above fluid is fine, I'm running Motul Dot 4 fluid along with slotted rotors and EBC yellowstuff pads. Take that as you will.
    Coolant: Regular green coolant is fine. Subaru recommends you add their conditioner to the mix.
    Engine oil: 5W30 is recommended.
    Cody
    May 2010
    WA
    What is LSD fluid?
    So far I have found that the trans and rear diff take about 4 quarts. Is that correct?
    How much does the front diff take?
    Ill most likely stick with the Subaru fluid since I just want to replace it and have it work normally.
    Jan 2005
    Eh, whaaaaa?
    Quote Originally Posted by wasisnt View Post
    What is LSD fluid?
    The WRX up to 2008 has a Limited Slip Differential in the rear. It's a special kind of differential that keeps differences in tire rotation between the two sides to a minimum and it requires a special fluid to keep it happy. Subaru has specific fluid for LSD's, which is what I mentioned.
    Again, the front diff and transmission share the same fluid in the manual transmissions. If it were an automatic you would have separate fluid for the trans and diff, but in the manual, it is combined, so you only purchase one fluid. Capacity is 3.7 QT.
    Cody
    May 2010
    WA
    Ahhh, got it. The LSD didn't click until you said limited slip diff.
    So 3.7Q each of the 75W90 from Subaru and I should be good to go
    Jan 2005
    Eh, whaaaaa?
    4qts total of the 75W90. Drain the tranny, fill through the dipstick tube, and you're good to go. Again, nothing different to do with the front differential, it's integrated with the transmission and just uses the trans fluild for lubrication, so only buy 4 qts of 75W90 and 1 qt (if it's available) of the LSD fluid for the rear diff.
    Cody
    May 2010
    WA
    Now I'm a little confused.
    When I drain the trans it will drain the front diff since they are connected? If so then it takes 4 quarts to fill the trans and front diff all at once?
    Then only 1 quart of LSD for the rear diff to fill it up?
    Jan 2005
    Eh, whaaaaa?
    Yep, that's what I mean by combined and shared fluid. 4 quarts total for the entire front part of the drivetrain. It also services the center diff. Trans + 2 diffs all with 4 quarts and one drain bolt.
    And yes, 1 quart for the rear diff.
    Cody
    May 2010
    WA
    I also just read about using a sealant on the plug threads. What do they recommend?
    Jan 2005
    Eh, whaaaaa?
    Nothing. Be sure to replace the gasket (washer) that goes on the plug, but other than that, no sealant on the threads.
    Cody
    May 2010
    WA
    Sounds good, thanks for all your help
    Sorry but do you mean anti-seize? If so that's not a bad idea IMO.
    May 2010
    WA
    I read some places that you should put some type of sealer or lok tite on the threads.
    I'm trying to find more info on the LSD fluid for the rear diff and am reading about LSD 90 but it may seem like people are using it only for the STI. Others say to use the 75w-90 in the rear.
    Nov 2009
    I think the transmission and rear differential both use the same fluid. It is something like Subaru Extra-S or something like that. The dealer will know. Also look at the owners manual it has all the info you need. That is if you have it.
    Aug 2008
    Kennett Square, Pennsylvania
    Manual trans fluid
    Brake fluid
    Coolant
    Thanks
    PCV valve, extremely important especially on a turbo car...
