White/Bluish Smoke from Exhaust-NOT TURBO SEALS
Results 1 to 10 of 10
This is a discussion on White/Bluish Smoke from Exhaust-NOT TURBO SEALS within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Ok guys, I have been noticing an issue with my 05wrx. I noticed that I lost that stage 2 pull ...
    Registered User 05scoobytooner's Avatar
    Aug 2009
    Vista,CA
    Ok guys, I have been noticing an issue with my 05wrx. I noticed that I lost that stage 2 pull in second gear and overall the car feels sluggish. I did a lot of post searching for what all the different things could be wrong and had a compression test and leak down test. The only problem is that the guys I did it through did not give me the results, so they claimed that everything was fine...so I was like ok so then it's got to be the turbo seals. It's burning oil like it's cool, so I had my real mechanic who normally does my modding on my car take the turbo out. There was really no shaft play at all and no signs of oil coming from or through the turbo at all!! I was like ****, then what else could it be?? He said that it could be leaking valve stems, but he said then the leak down test should have came back NOT normal. So should I just have my mechanic do another compression and leak down?? I have to change the oil every 2000 miles, and I change the spark plugs too. The spark plugs had old oil over all four of them, so any luck with any of you guys experiencing this?? 100,000 miles on the car, was running perfect before recently. Thanks guys for any feedback.
    Aug 2008
    Kennett Square, Pennsylvania
    When do you notice the blue/white smoke coming out of the exhaust? I would go back to the shop that did the tests and demand results, after all I'm sure you paid a pretty penny to have them done...Is it more blue or more white? Is the CEL illuminated/ any codes stored? Does the car overheat at all? Are you low on oil or coolant more?
    Aug 2009
    Vista,CA
    I never had any cells thrown to begin with it. the car does not over heat and the oil goes quick its gets low after a couple thousand miles. Coolant is fine and it smells like oil and has a bluish tint to the smoke at idle. Its hard to notice when in moving but for sure when the car is at a light or something...
    Check the PCV system.
    Nov 2009
    What kind of oil are you using?
    Aug 2009
    Vista,CA
    i use purple royal 5w 30 and you guys think a pcv valve could have me lose power and cause that much bad smoking?
    Quote Originally Posted by 05scoobytooner View Post
    Unlikely.
    Possible.
    Since you took it to a shop, and they did a leak down test (and provided the ultra-thorough "OK" result...) did they mention what might be the issue?
    Leaking valve stems are IMO unlikely, and in any case would cause a smoke screen upon startup I'd guess -- then they would probably settle down while driving.
    I'd go to a shop that is willing to diagnose the car and have them diagnose the car. Tell them the turbo result since that's work and $ to repeat, and tell them the rest but ultimately if they want to do another leak down I would not fault them.
    Do you have a catch can? How is it routed? Any noises, clanking, rough idle?
    Fouling plugs that often is definitely a sign of a problem. Are you able to log? Is the mixture OK or is the car running rich? BTW you don't have to change the oil that often, just top it up.
    Moderator Donkey's Avatar
    Da boonies,Va
    Honestly I would try a different oil. Maybe a 5w-40 or 10w-40 and see what happens. You definitely need the results of the compression and leakdown test.
    2002 FORESTER S
    1998 FORESTER S
    Aug 2009
    Vista,CA
    Unlikely.
    Possible.
    I'd go to a shop that is willing to diagnose the car and have them diagnose the car. Tell them the turbo result sincen. that's work and $ to repeat, and tell them the rest but ultimately if they want to do another leak down I would not fault them.
    It does settle down a little when driving, but as soon as it is at idle, huge smoke screen.
    I am going to have my mechanic do another leak down, because the other shop did not log in their computer what my reusults were, probably the worst shop I have ever been too...
    No, no catch can, idle is good.
    They did mention the seals or leaking valve stems at the time and wanted me to leave the car overnight to do more searching, but I couldnt because it is my DD.
    All I have is an accessport...I know my car is running rich because I get 15 miles to the gallon...
    I was thinking about the PCV valve before I posted this, but thinking that it being such a cheap part, and never reading up on anybody who has my same problems with their car being the PCV valve...I held off
    Aug 2009
    Vista,CA
    So just to update you guys, my leakdown result yielded 2 and 4 pistons or cylinders leaking 35% and 40% and 3 and 1 cylinders 20% and 15%...ya so that would explain the smoke and the loss of power...this sucks...
    sooo I'm going to take advantage of this opportunity and get some JE pistons and better rods and bore them out to make them larger...
    Thanks again guys!
