could it be only the fuel or something else
Results 1 to 15 of 15
This is a discussion on could it be only the fuel or something else within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; hi everyone im from guatemala and i have a problem, three weeks ago i go to the gas station and ...
    Registered User carlosdevil10's Avatar
    May 2010
    Guatemala
    hi everyone im from guatemala and i have a problem, three weeks ago i go to the gas station and the gas attendant full my tank with regular fuel that is under 93 octanes so my car start feeling very bad so i get that fuel out of the tank and refuel with good fuel 95 octanes and reset the ecu, and have already fuel the tank 3 times and still cant get boost over 10 psi and the over the 5000 rpm it starts to detonate and the check engine light starts to tilt what could it be and what to do ?? thanks sorry for my english
    May 2007
    orlando flawduh
    hey- dont apologize for your english. it's 10 times better than some of the members here who are from the USA
    you said your check engine light came on- have you been able to get the code to see what it's for specifically?
    desiree
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    Quote Originally Posted by wrxtreme06 View Post
    +1 on both accounts
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
    May 2010
    Guatemala
    no , i havent get the code i dont have a scanner so maybe some help without the code?, all the problem start after the regular gas
    Dec 2003
    Dallas, TX / Sterling, VA
    There is no way to help you unless we know what the code is. So you're misfiring at 5k RPM?
    May 2010
    Guatemala
    Quote Originally Posted by brfatal View Post
    yeah something like that could it be injectors or ignition im sad i cant feel the boost
    Nov 2006
    Denver Metro Area
    I see a front mount... what other modifications do you have?
    Kevin
    Moderator
    WRX Gas Mileage FAQ
    May 2010
    Guatemala
    mmm i have the front mount intercooler, forged pistons, fuel pressure regulator, bigger injectors, a td06-20g turbo, perrin fuel rails, 3' sr-s exhaust system, and it has tuned for 17 psi,
    Registered User Pavia's Avatar
    Dec 2006
    Philly/DE area
    Try changing the fuel filter. Maybe the bad fuel clogged it...idk.
    06 GTO M6 Quicksilver, SLP 455 Bobcat, LS7 Clutch w/ SS line (RPM tune:373rwhp/373rwtq)
    07 WRX TR M5 Garnet Red Pearl w/ Straight PPGs and Cusco front LSD (Agile tune:307whp/343wtq)
    Registered User mexicanzero's Avatar
    Oct 2009
    Ottawa Ontario Canada
    did you reset the ecu after the fuel problem? (unplug the battery for a while)
    it really would help to know what codes are in there, take it to a local shop and ask very nicely and they might do it free
    -Alex
    LIVE LOUD, ROCK HARD!!@
    2003 WRX wagon 16g + 6 speed
    May 2010
    Pittsburgh, PA
    Most shops around us like advanced auto will read them for free, they just loan you their scanner for 5 minutes.
    2011 STi Build Log
    May 2010
    Guatemala
    Quote Originally Posted by mexicanzero View Post
    -Alex
    yeah i reset the ecu everytime i put new gas thinking it will help but nothing, it stocks in 10 psi
    May 2010
    Guatemala
    i will take it to the mechanical this weekend to check injectors and change fuel filter, also get the codes.
    May 2010
    Guatemala
    hi everyone today i take the car to the mechanic and he borrow me the scanner the codes that the ecu shows are P1087 and P1088, could it be the troubel, also my abs light turns on when i put reverse
    Jan 2005
    Eh, whaaaaa?
    Quote Originally Posted by carlosdevil10 View Post
    P1087 = LH TGV circuit high input
    P1088 = RH TGV circuit low input
    Something is wrong with your TGV's.
    Cody
