Looking for answers.
Results 1 to 11 of 11
This is a discussion on Looking for answers. within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Noon here. Just got an 02 hatchback wrx and noticed some things that don't seem right. First, when I start ...
    May 2010
    Fuquay-Varina
    Noon here. Just got an 02 hatchback wrx and noticed some things that don't seem right. First, when I start it up after it's been sitting for a few hours it has a loud knocking sound, but it goes away after about a mile of driving. Also when I'm sitting with the engine on and in park it will start to shake a little, and only in park. The car has a brandnew timing belt and water pump. The only thing wrong that I know of is the CEL that gets thrown from my tumble valve.
    Any thoughts?
    Jan 2005
    Canada B.C.
    Sounds about right to me... My '02 ran the same 6 - 7 years ago, and is still running great.
    '02 WRX 4EAT, 311,000KMs/194,500Miles, Sold. Best car I ever had. '09 STi stage 1, hope this one will be good too...
    May 2010
    Fuquay-Varina
    Ok cool, good to know. Also it seems to eat gas like mad, figured that was just the car though.
  5. #4
    May 2010
    Pittsburgh, PA
    Aren't known to make it further than a hybrid in the desert to say the least, but if you want to check into it, maybe look into getting your car tuned. Might run a bit smoother and eat up less (or more) gas.
    Said you just picked it up, so wasn't sure if it had any engine management in it or not.
    2011 STi Build Log
  6. #5
    Oct 2005
    Late Devonian
    I thought it wasn't supposed to run properly with the tgv delete cels active. I don't think you are supposed to drive it like that but am not that familiar with the mod personally.
  7. #6
    Jan 2005
    Eh, whaaaaa?
    Engine knocking in any form isn't normal....
    Idle and operation will be effected by the TGV deletes. You need a custom tune to account for this.
    Cody
  8. #7
    Piston slap is normal; early motors "fixed" under warranty simply started slapping again and I've not heard of anyone having any further issues from that. Knock is not normal, but since the noise goes away slap is likely.
    It is unclear at least to me whether the OP has deleted the TGVs or simply has a TGV CEL. Either would explain rough running.
    - Al Stewart
  9. #8
    May 2010
    Fuquay-Varina
    So just getting a new tumble valve should help. I heard that it really only helps with cold starts. Also I couldent find my tumble valve from a picture. Any help?
  10. #9
    Quote Originally Posted by cgsimmang View Post
    I never said that. In fact I find it more likely you have an electric/onic problem -- what is the CEL?
    What is "it" above? I'm confused.
    - Al Stewart
  11. #10
    May 2010
    Fuquay-Varina
    It is the tumble valve. The cel was eaither p1066 or p1099 I don't remember.
  12. #11
    I don't think either of those are valid codes. I think the TGVs tend to generate one or more of the following:
    P1086 Tumble Generated Valve Position Sensor 2 Circuit Low
    P1087 Tumble Generated Valve Position Sensor 2 Circuit High
    P1088 Tumble Generated Valve Position Sensor 1 Circuit Low
    P1089 Tumble Generated Valve Position Sensor 1 Circuit High
    P1090 Tumble Generated Valve System 1 (Valve Open)
    P1091 Tumble Generated Valve System 1 (Valve Close)
    P1092 Tumble Generated Valve System 2 (Valve Open)
    P1093 Tumble Generated Valve System 2 (Valve Close)
    P1094 Tumble Generated Valve Signal 1 Circuit Malfunction (Open)
    P1094 Tumble Generated Valve Signal 2 Circuit Malfunction (Open)
    P1095 Tumble Generated Valve Signal 1 Circuit Malfunction (Short)
    P1097 Tumble Generated Valve Signal 2 Circuit Malfunction (Short)
    In any case check the clips and wiring. My guess is you have an electrical issue.
    Also see:
    Cel p01092 - tgv
    and
    Help on CEL code P1086 - Tumble generator valve
    or
    Cel p1090
    and definitely see this, if it comes to that (it might; see this for sure anyway):
    http://www.scoobymods.com/tgv-sensor...88-t5160.html?
    EDIT: Emphasis on last post for part description. Remember, if it comes down to actually needed to replace a sensor, you can do it even though Subaru may not sell you a sensor alone -- it's the same sensor and it is sold separately but not as a "TGV sensor." Hopefully you only have a loose connection though.
    - Al Stewart
