Does anyone know what this noise is? :-( YouTube video...
Results 1 to 8 of 8
This is a discussion on Does anyone know what this noise is? :-( YouTube video... within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Got this noise and it's getting worse and worse.. Louder in 4th and 5th gear - 60 MPH +. Quite ...
    May 2010
    Unhappy Does anyone know what this noise is? :-( YouTube video...
    Quite hard to hear on the video unless you know the sound and listen out for it...
    It comes on when you put your foot on the accelerator, and goes away completely when you lift off...
    Had timing belt, all tensioners and water pump changed..
    Tried running without alternator + A/C compressor belts on - still the noise remains
    Any ideas anyone please
    YouTube Video - Subaru WRX Whine - 4th + 5th Gear
    Registered User FyrHazard's Avatar
    Mar 2010
    Iowa
    Have you checked your transmission oil level?
    "Good design is a lot like clear thinking made visual." - Edward Tufte
    Bugeye Mafia #314
    May 2010
    Yes mate, I thought that, level is perfect
    Mar 2010
    Iowa
    Does it change when going around corners?
    Some other things to check: Tire pressure, driveshaft boots, propeller shaft joints, wheel bearings, rear differential fluid.
    Bugeye Mafia #314
    May 2010
    Cheers, i will check those... no change around corners, just 60mph + gets louder and louder..
    Mar 2010
    Iowa
    I'm just making suggestions for anything that could be making noise like that. It is odd that it goes away when you let off the accelerator. I don't think it is wheel bearings (could also be cupped tires), but those wouldn't stop making noise when you let off.
    I've ridden in some cars that the rear differential will make a whine when you let off the gas and coast with everything still in gear.
    Bugeye Mafia #314
    May 2010
    I was thinking on the lines of rear diff aswell, but what is strange is that the noise goes away completely if you put it in neutral and roll
    Oct 2005
    Late Devonian
    I would also guess differential noise.
