Ignition Coil Resistance
Results 1 to 8 of 8
This is a discussion on Ignition Coil Resistance within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Does anyone know the resistance in ohms for an ignition coil for an '03 WRX? I have researched this via ...
    May 2010
    I have researched this via the web but have found out the resistance can only be found in the vehicle repair manual. Can't find a repair manual for an '03 and can't find the resistance for the coils of an '02 or '04. I haven't called a dealer to find out, but hesitant to do that.
    What I'm trying to do is test the resistance with a multimeter. Have seen posts where some say it's not possible with these ignition coils but I still want to give it a try. Also I have heard that the ignition coils last for a long time. However, don't know if mine have been replaced by the previous owner(s) and I'm pushing 109k therefore I'm thinking at least one might need to be replaced due to an ignition coil/wire test I ran.
    Any useful info would be appreciated.
    From factory manual
    C: INSPECTION
    Ignitor is integrated with the coil. Therefore resistance
    cannot be measured
    If you are getting a CEL, it will be specific to one cylinder. Try switching components to see if you can get the CEL to track the component to troubleshoot. If you are not getting a CEL and the car runs fine, I'd just put everything back together.
    May 2010
    Thanks for the info. Saves me the trouble from pulling those hard-to-reach buggers out.....again.
    BTW, would a slight hesitation from 500 - 2000 rpm be caused by bad fuel injectors or possible a bad PCV valve?
    PS: no CELs, just the hesitation.
    The stock tach cannot measure 500 rpm and the car does not idle at 500.
    I'd like to think that an ignition-related hesitation would generate a CEL, and that a clogged PCV would increase oil consumption. Likewise, a vacuum leak ought to also generate a CEL -- but in any case that's were I'd start just because it seems somewhat reasonable. Just an opinion.
    May 2010
    Thanks SD_GR,
    That is a good guess because I am using oil and I am at the cusp of changing the PCV valve which is (I'm assuming) older than dirt. I'll examine the hoses to see what I've got. Glad to know for now that it's not either the injectors or the coils.
    Mar 2010
    Quote Originally Posted by spacebarcode View Post
    i dropped one of my coils and i dont remember which one and the car will not stay running...wen i tested the ohms i got 5.24 from one and 34.67 from another so im guesing the 5.24 is the bad one..mine is also an 03 and i just hit 108k and theyve never been changed
    May 2010
    jerzeyninja, how did you test your coils? I tried with a multimeter but got nothing and a lot of users are saying that it's not possible.
    thanks for the help.
    Apr 2015
    No one has replied to this either... The 02 wrx I have have a 3 prong connector to the clip. Well if you look at the clip white front, or black back there should be the trigger wire green, then red power, and finally black ground I believe... Since I hooked my multimeter to two of my coils red on red black on black I got 8.38 on one and 8.15 on the other... Any other combination of the leads and prongs did not show a reading... Still what is the resistance of a new or good coil? Thinking I need some the car is not happy ;/
