you might have a leak... check vac. lines. and stock boost max is .1
This is a discussion on turbo loosing boost within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; i have stock gague since i bought the 03wrx the boost gague has never gone above .1 now every now ...
i have stock gague since i bought the 03wrx the boost gague has never gone above .1 now every now and then it wont go above .5 after i changed oil in car it went back to .1 but never higher now its not going above .5 on boost gague any help would be great also should factory boost gague get up close to .15 please let me know
VF-43 Bugeye: OPEN SOURCE tune... 121xxx miles
13.1@105... Lazy launch 1.9 60'
285whp and 300WTQ.
thank you i will look at vac lines and thankks again for letting me know stock boost is .1
Yes, you won't see .15 unless you are modified. And as wrxlaunch said, max on stock set up is .1 or very slightly under.
Good luck, if its a leak, hope you find it.
02 MBP Stg 2 Bugeye
Bugeye Mafia #107
WRB '02 Stage 2+ WRX - SOLD (and dearly missed)
07 OBP WRX (Wife's) SOLD
In your case it sounds like the ECU is pulling boost when you see .5 (you need to be able to log the IAM to tell). If that is the case it could be a variety of mechanical issues like vacuum or boost leaks (which could also potentially be sufficient to explain the low boost), fuel, etc.
get an OBD II scanner and check if ur ecu has stored any codes without triggering the CEL. Clean MAF and check for leaks, exhaust and vac; ie exhaust before the turbo. and possibly check turbo inlet if u can, intercooler couplers... etc
285whp and 300WTQ.
