What and why exactly causes the the stock wrx intercooler y pipe to split or crack?
Results 1 to 5 of 5
This is a discussion on What and why exactly causes the the stock wrx intercooler y pipe to split or crack? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I heard WRX's have a bad history of having their stock IC y-pipe split or crack under boost. What exactly ...
    May 2010
    Japan
    I heard WRX's have a bad history of having their stock IC y-pipe split or crack under boost. What exactly and why does it do that? Are the stock WRX's not meant to be boosted if thats the case? Sorry for the noob question. I new to cars. Thanks for your help!
    Nov 2009
    I haven't really heard this, but my theory would be that the plastic gets brittle after a while and then eventually cracks.
    Aug 2008
    Kennett Square, Pennsylvania
    Quote Originally Posted by oguitar View Post
    +1..Theres alot of heat under that intercooler..combined with years and thousands of miles of wear...I have never really heard or seen it as a "common problem" though...
    May 2010
    Japan
    Could this be a cause? Let say you installed an bigger aftermarket exhaust, like a straight pipe. Since there's less back pressure and more flow compare to the stock exhaust, when boosted more air go into the IC, through the engine and the exhaust thus more heat generated. More flow = more heat. The stock IC plastic y-pipe is not made to handle that much flow and heat, therefore results in the brittle stock y-pipe to burst or crack. Does this theory make sense?
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    plastic doesn't like to be heated, then cooled over and over and over again. the 2006+ wrxs actually have a foam insulation over the plastic piping to protect it from the heat of the engine and transmission below it.
    Your theory about exhaust doesn't work.... the EGTs are the same temperatures at the same AFRs... now, increased PRESSURE actually increases the charge temperature. (the post turbo temp).
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
