Pulled spark plugs, all looked good. I think there may be 2 different problems. I don't think the valve spring problem, if that's what it is, will cause a low boost problem but I'm completely out of ideas. Did compression check again and it was 150 on 2 cylinders and 165 and 175 on the other 2 cylinders. Way different then the first time. I know that 7psi is the allowable difference between cylinders. I know compression range is 148psi to 185psi. Maybe compression test wasn't done right first time. This result has me leaning towards some sort of timing problem. Gonna pull the front cover and check timing belt and maybe reset timing just to be safe. Feels like I'm working in circles
LinkBack URL
About LinkBacks
