Can someone tell me how to fix this..
Results 1 to 10 of 10
This is a discussion on Can someone tell me how to fix this.. within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have a 2010 wrx sedan... i got a dyno tune.. hks SSQ blow off valve.. cold air intake... and ...
    Apr 2010
    I have a 2010 wrx sedan... i got a dyno tune.. hks SSQ blow off valve.. cold air intake... and all of a sudden, after installing my invidia downpipe.. after i get up to 4500 RPM in 3rd.. the car kind of mis-fires.. and my check engine light comes on along with traction control and cruise control lights... it was still running fine.. but then all of a sudden today the blow off valve just stopped working and now my engine is running kind of sluggish.. can someone tell me why this happened and how to fix it?>
    Aug 2009
    Canada/Ethiopia/Madagascar
    You got tuned before the downpipe install? I'll guess that that's your problem. You may be overboosting, so your car cuts off the fuel supply to prevent any engine damage.
    The downpipe most definitely needs a tune to maximize benefits and prevent your car from say "NO!"
    ...Rob.
    Moderator T0rque's Avatar
    Dec 2004
    Medford, Oregon
    You need a new tune.
    Lead Wrench @ WTF Tuning, LLC
    Mar 2010
    Woodland Park, CO
    1. Check the ECU for any stored error codes, make a note of these.
    2. Disconnect the battery for a minute or so to hopefully reset it and make the car more drivable.
    3. Get an ECU tune that works with the modifications you have, and in the meantime, go very easy on the throttle and keep the boost low.
    Apr 2010
    okay... so will i need a new blow off valve then?
    Mar 2010
    Woodland Park, CO
    Quote Originally Posted by dmoorewrx10 View Post
    Installing an aftermarket downpipe generally requires a different ECU tune, at least from what I've seen/read. BOV is probably not your problem.
    Dec 2004
    Medford, Oregon
    You probably have a pinched vacuum line by the blow off valve. You don't need a new one. You need a new tune since you were tuned before the install of those parts
    Registered User 2.0Rs's Avatar
    Jul 2007
    King of Prussia, Pa
    New tune. Should have waited till you put that downpipe on to get the tune. I wouldn't recommend flooring it till you get that problem fixed. The fact that your cars ecu is saying wtf is happening here everything is flowing way more then what I'm putting out it's saying it's not right and cutting your fuel to prevent damage. aka it's saying I don't like it don't do it again.
    Oct 2005
    Late Devonian
    Yup, I'd put money on it having over-boost codes. You have to get it retuned right away.
    The BOV should be fixed ASAP too whatever it is doing. Are you hearing any compressor surge?
    Jan 2005
    Eh, whaaaaa?
    Cody
