Failing TMIC?!?
Results 1 to 4 of 4
This is a discussion on Failing TMIC?!? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So while in low boost my BOV works perfect. But when in high boost it isn't working at all... the ...
    Registered User jraney2008's Avatar
    Mar 2010
    BELLINGHAM, WA
    Failing TMIC?!?
    So while in low boost my BOV works perfect. But when in high boost it isn't working at all... the BOV seems to work fine though, I took it apart and everything seems fine.
    My TMIC has about 120k on it. Is it time to replace it?
    Thanks
    Jul 2004
    Seattle, WA
    If the intercooler is holding boost then it's not a problem with the intercooler.
    Try the stock BPV, even if it looks fine the aftermarket BOV is likely the problem.
    Dec 2003
    Dallas, TX / Sterling, VA
    So why would you blame an intercooler for something that a BoV is doing wrong? You really haven't stated what exactly the problem is.
    Nov 2009
    An IC is a very simple part. Unless you have something clogging up the internal section or got a leak in it. Your IC is probably not the cause of your problems.
