Results 1 to 5 of 5
This is a discussion on fast blinking directional within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; My WRX's driver side directional is flashing very fast. Normally I thought it would be a lamp out. But both ...
    JT7
    JT7 is offline
    Registered User JT7's Avatar
    Jan 2010
    Kewaskum, WI
    My WRX's driver side directional is flashing very fast. Normally I thought it would be a lamp out. But both rear and front are illuminating. The hazards flash normal when engaged.
    Any thoughts as to what this might be (relay etc?) If going to the dealer wasn't such a pain in the ass I would make them earn some money. If it's just a loose relay, bulb etc then no big deal.
    Thanks
    2010 Obsidian Black 5 Door
    - Stink Eye Mob #190
    Aug 2008
    Kennett Square, Pennsylvania
    Quote Originally Posted by JT7 View Post
    Thanks
    Are you sure both of them are as bright as they normally are?...I would still prob pop the bulb out and replace it to start with....
    JT7
    JT7 is offline
    Jan 2010
    Kewaskum, WI
    Yea - because when the hazards are on they look identical on both sides - front and back.
    Registered User vttk_mig69's Avatar
    Jan 2008
    Sheboygan, WI
    do the hazards blink at normal speed and just the directionals blink fast?
    had that prob with my moms car and it turned out half of the relay was bad because it controlled the directionals and the hazards so the hazards worked fine but the directionals blinked fast.
    JT7
    JT7 is offline
    Jan 2010
    Kewaskum, WI
    That's what I was thinking because that is exactly what is happening.
    Thanks
