Clean up that wayward grease so you can get a better look at the boot. Looks like it's leaking past the clamp.
This is a discussion on Help diagnose: Inner CV damage? (pics included within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hey all, I have a 2003 WRX that is stock. I noticed a large amount of dark green grease on ...
Hey all, I have a 2003 WRX that is stock. I noticed a large amount of dark green grease on my passenger side axle. After spending a bit of time searching through posts, I decided to just take picture and was wondering if someone could confirm what the problem is and maybe offer me some solutions. I didn't see any actual tears on the boot, and there was no unusual sounds coming from my car... like I said, I just happened to see the grease while the hood was up.
Here is an image from above, front of the car is to the right:
And here is a view from under the passenger tire:
...Rob.
The inner DOJ boots do leak grease around the outer (smaller) clamp area, Somewhat common occurance on Subarus in general..Chances are you wont be able to tighten the clamp, from the pics it doesn't look like most or all of the grease was lost so personally (as long as you don't hear any noises from the joint itself) I would pop the clamp off and just wrap a new on...and clean everything off obviously...![]()
Thanks for the replies. I wiped it down and took more pics.
Although I didn't jack up the car to get in real close, I couldn't see anything that would indicate what's wrong. The pictures look better than looking at it in real life. The idea that it is a just a plain old leak makes sense to me. Ideas?
I've noticed an almost burning smell recently and took a look under the car. I found the same dark green grease all over the passenger side axel and down the exhaust. My passenger side boot is torn though.. sorry for the poor photos, it was dark out and I only had my phone around.
Anyone find link(s) on fixing the problem?
I've been reading a bit about torn boots, and let me be the first to say that I have very limited hands-on experience with cars... but you probably want to take care of that problem as soon as possible. If you know your boot is torn, you need to get it fixed, probably by replacing the whole axle.
If you would like something to click on, try this:
http://legacygt.com/forums/showthrea...ot-108975.html
a good read, although in most circumstances replacing just the boot is not the best way to approach things. Search around, there's lots of info if you just want to get a general idea of what you're in for.
Replace the boot before the DOJ actually starts making noise. Than you have to replace the entire axle. I have said it before and I will say it again Subarus are extremely touchy with certain aftermarket components ( thermostats, ignition components and axles just to name a few ). A Subaru OEM reman. axle wont be cheap, If you can do the job yourself and just replace the boot your looking at about $50 in parts, however if you need an axle it will be a few hundred...
Thanks for all the info so far, but I'm going to need a little more hand holding. I read a post from EvoEatr explaining how to pop off the small clamp of the DOJ boot, but from that description, the clamp I ordered, which should have been the OEM part, doesn't quite look to be the same as the original clamp.
I've never used a clamp like this. My best guess (with help from the auto parts store person), is to wrap it around the boot twice (passing it through the tab twice), pull it tight with one pair of pliers use a another set of pliers to somehow pinch it shut. Then cut off the excess if there is any. Or maybe bend it back the opposite way.
However, this doesn't seem intuitive, and I also don't know what I am going to use for leverage to pinch the tab shut since one side of it should be flush against the boot, and if that will actually be tight enough to stop the leaking anyway.
I'll be happy to answer any questions to make my problem clearer, or post more pictures.
The service manual says to use a tool (part #925091000) to tighten this clamp, but it costs $75. Anyone have any suggestions as to how to apply this band with just a couple sets of pliers? How do you guys do it when replacing the boot? Should I just buy a generic boot band instead?
