Power Steering Fluid Compatibility
Results 1 to 15 of 15
This is a discussion on Power Steering Fluid Compatibility within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I'm thinking about changing the power steering fluid on my 2009 2.5i now that I'm almost at 30k miles. Question: ...
    Nov 2008
    Question:
    I have heard that some cars can take ATF instead of PSF but my manual only states PSF it says nothing about ATF. Can I use ATF?
    I went to Advance Auto Parts today and saw Valvoline MaxLife in a red bottle PSF for $4 for a quart. Is this stuff any good?
    Aug 2009
    Canada/Ethiopia/Madagascar
    If it calls for PSF use PSF. Each fluid will have different additives that can/will reak havoc if used inappropriately.
    Most, if not all Toyotas call for ATF, I'm sure a ton of people ended up with leaking racks when they put PSF in.
    ...Rob.
    Registered User JUSTINSNUTSWINGER's Avatar
    Jul 2008
    San Antonio
    Get the ATF/PSF from the dealer. $9 quart
    N-swinger
    2000 Escort
    Maintenance schedule and poke in the eyes:
    http://www.clubwrx.net/forums/genera...nce-guide.html
    Moderator T0rque's Avatar
    Dec 2004
    Medford, Oregon
    go to subaru parts counter.
    Ask for Power Steering Fluid for said model
    Buy fluid.
    At all costs avoid napa, oreillys, schucks, autozone.
    Lead Wrench @ WTF Tuning, LLC
    Moderator Donkey's Avatar
    Da boonies,Va
    It uses ATF (Dextron III) for PSF.
    2002 FORESTER S
    1998 FORESTER S
    Nov 2008
    Now i'm really confused! I just went on the amsoil.com site to look at fluids and came across a vehicle selection menu that matches the fluids meant for your vehicle. It listed ATF as the PSF. I may just go to the dealer for the fluid. The manual is confusing me.
    Registered User Pavia's Avatar
    Dec 2006
    Philly/DE area
    How often do folks generally change the PS fluid?
    06 GTO M6 Quicksilver, SLP 455 Bobcat, LS7 Clutch w/ SS line (RPM tune:373rwhp/373rwtq)
    07 WRX TR M5 Garnet Red Pearl w/ Straight PPGs and Cusco front LSD (Agile tune:307whp/343wtq)
    Dec 2004
    Medford, Oregon
    Dec 2004
    Medford, Oregon
    Quote Originally Posted by Pavia View Post
    I recomend 30k intervals.
    Dec 2006
    Philly/DE area
    So ATF Dexron III is no longer made. I assume there are equivalents on the auto stores's shelves.
    Do you all suck the fluid out of the reservoir tank or flush it from the pipe joint in center of gear box?
    It never occurred to me to do this, because the manual only said Inspect. good stuff....
    Da boonies,Va
    You can use Dextron IV. NASIOC has some good DIY on changing PSF.
    2002 FORESTER S
    1998 FORESTER S
    Dec 2006
    Philly/DE area
    Just read through it... I think I can raid the kitchen cupboard for a baster... lol.
    I found one comment interesting... Basically, the ATF fluid in an auto tranny gets dirty over time because of the dust and material coming from the action of the transmission. The ATF fluid in the powersteering, however, doesn't see this kind of use or is exposed to residue, so, in theory, it shouldn't really need replacement anytime soon.
    It got me thinking about the PCV valve too.
    Nov 2008
    I'm going to use a pump from a shower gel bottle to pump the old fluid out. I went to Advance Auto Parts again and this time the cashier looked up the fluid requirements in the computer. He directed me to Dexron III/M. Advance Auto Parts sells it under it's in store brand name for $3 per quart.
    Dec 2006
    Philly/DE area
    Quote Originally Posted by Marukai View Post
    That sounds like a good idea. You could do it a couple times to dilute the old fluid enough.
    Dec 2003
    Dallas, TX / Sterling, VA
    Ditto.
