Results 1 to 8 of 8
This is a discussion on Engine won't stay running within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have a 2004 subaru wrx with some mods on it including a ecu reflash. Went to replace the spark ...
    Apr 2010
    Went to replace the spark plugs yesterday and put everything back together and the engine doesnt want to stay on. Almost like the timing is off. this is not the first time that i replaced the spark plugs so i know that i couldnt have put the cop harnesses on the wrong one.
    the engine cranks and turns over then dies right away almost like the map sensors not plugged in. it feels like you need to give it some gas but if you do so the engine dies even faster.
    So i went back and double checked everything and even put the old spark plugs in and still nothing. I checked fuel pressure which i have. i looked at the new spark plugs and you can see that they have been firing which means i have spark so the coil on plugs are good. i dont know anymore.
    i was going to check the coils on their own but am not sure how to do so. how do you check the coil on plug? what would be the likelyhood that its my ecu? i've unhooked the battery before and never had that happen.
    hooked up my scanner and no codes show up because the codes get erased when i unhook the battery and i cant get the codes to come up cause the engine wont even stay on.
    please help...
    Registered User Dos-fivewagon's Avatar
    Dec 2009
    portland
    need to to know what other mods. could be anything from a stuck bov to a bad coil to a dirty maf etc.
    One industrial accident away from financial freedom!
    Blobeye Syndicate #215
    Apr 2010
    Ok... helix dp and up, blitz nur catback, hks bov, borla headers, fmic, vf22, modded wrx injectors, perrin ebc, aem shortram intake, reflashed ecu
    Apr 2010
    bump
    Jul 2008
    San Antonio
    What plugs did you put in ? Also, did you chk the gapping?
    Paul
    2007 MS3
    Maintenance schedule and poke in the eyes:
    http://www.clubwrx.net/forums/genera...nce-guide.html
    Apr 2010
    I put in the oem plugs. ngk's and yes the gapping was correct.
    Jan 2005
    Eh, whaaaaa?
    Have you checked to make sure the electrical connections on the coils themselves are tight and that they are sitting on the plugs correctly?
    Cody
    Apr 2010
    Yes, i have checked everything like 5-10 times.
