Ive done a few of these recalls on the WRX, most notibly the little coolant line that is kind of on the side of the surge tank that comes up between the cylinders #1 and #3 intake runners gets seriously corroded/stuck on the surge tank and you have to get that line off in order to remove the intake manifold properly, personally I would first check there ( I'm not going to lie I have broken a few )...Also if you have the means do a cooling system pressure test, the leak should become apparent, of course you could also take the car back to Subaru...
LinkBack URL
About LinkBacks
