Results 1 to 8 of 8
This is a discussion on BOV whistles loud after STI TMIC install within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; title pretty much says it all, STI TMIC with the stock WRX bov. As soon as I hit around 2 ...
    Registered User ej20_allday's Avatar
    Apr 2009
    Chi-town
    title pretty much says it all, STI TMIC with the stock WRX bov. As soon as I hit around 2 psi, it starts to scream!
    Doesn't appear to be losing boost but is this okay?
    I keep my scooby clean
    Dec 2003
    Dallas, TX / Sterling, VA
    Sounds like a leak to me. Did you re-use the gasket?
    Apr 2009
    Chi-town
    unfortunately, yes
    Registered User fire_cky's Avatar
    Jul 2007
    Philly
    Quote Originally Posted by brfatal View Post
    sounds like a leak to me. Did you re-use the gasket?
    +1
    '02 wrx wagon:
    various cobb things here and there.
    LoneWolfBugeye #01
    Jul 2004
    Seattle, WA
    Sounds like it's loosing pressure somewhere.
    The BPV should not make noise at any psi.
    How are you measuring boost?
    Are you sure it's coming from the BPV?
    Did you hook the hose back up to the BPV?
    Did you torque the bolts holding the BPV to spec (12ft/lbs)
    Apr 2009
    Chi-town
    i'm hitting the stock boost like I should, 14.5 or what ever it is
    Apr 2009
    Chi-town
    Quote Originally Posted by jeremy96gase View Post
    guess the bolts weren't torqued all the way, doesn't whistle anymore
    Jul 2004
    Seattle, WA
    Very strange.
    Normally, it's difficult to hit target boost if there is so much air leaking from the system that the driver can hear it.
    Well, whatever, glad you got it fixed
