96 wrx not wanting to fire
Results 1 to 8 of 8
This is a discussion on 96 wrx not wanting to fire within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; driving the car engine jus stopd. engine winds over but will not fire any ideas? oil is a little bit ...
    Apr 2010
    driving the car engine jus stopd. engine winds over but will not fire any ideas? oil is a little bit low in the engine is it possiable for the engine to stop because there is low oil in the car? it is a subaru wrx 1996
    Jan 2005
    Eh, whaaaaa?
    My first guess is fuel filter being clogged or fuel pump going out. Oil level being low won't cause it to stop firing, but if it's too low the motor could seize, but it doesn't sound like you got it that low.
    Cody
    Apr 2010
    where would i find the fuel filter? i have no manual
    Jan 2005
    Eh, whaaaaa?
    I believe it's just like the 2002 WRX here in the states, should be in the right side of the engine bay near the firewall. You'll see two lines coming out of it, one is the line in from the tank, the other is to the fuel rails.
    This might help:
    GC8 Impreza WRX STi Fuel Filter Change - JDMVIP Forums JDM Japanese Cars Import Used Auctions
    Cody
    Apr 2010
    ok ive taken off the filter and tested it, its fine, i tryd starting the car without it there and there was no fuel coming through the line so im guessing a problem with the fuel pump, now i know there is a pump inside the car on the passangers side but is there one at the tank aswell? and if so is there a way to tell which of the two is the problem?, im only going by what ive read about the car online so sorry if i am wrong about how many pumps ect
    Jan 2005
    Eh, whaaaaa?
    Quote Originally Posted by xxXStylusXxx View Post
    There should be a fuel pump in the tank. Check under the carpet in the trunk, passenger side. You should see an access panel there for tank access, 4 screws I think. Remove it and you should see the top of the pump assembly.
    Take a look here:
    Diy - Gc8 - Walbro Fuel Pump Installation - Rexnet Subaru Forums
    Cody
    Apr 2010
    ok thanks that helpd, so from what ive said about trying to start with no fuel going from the house that leads into the filter can i be sure that there is a problem with the fuel pump at the tank? alot of money if im wrong
    Jan 2005
    Eh, whaaaaa?
    Fairly to mostly certain that's the cause. If you're not getting any fuel pumped to the filter, it's either a major blockage in the line, or the pump itself, my money is on the pump. Might want to look into an aftermarket pump if one is available. You may be able to save some money on a Walbro over a stock pump.
    Cody
