1998 wrx import wiring issue with the mass air flow sensor
Results 1 to 3 of 3
This is a discussion on 1998 wrx import wiring issue with the mass air flow sensor within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Some donkey before i purchased it decided to cut off the plug to the air mass meter?? It has been ...
    Apr 2010
    It has been spade connected to the terminals on the air mass meter but im thinking they are not connected in the right order as the car has suddenly started mis-firing and majorly overfuelling!!
    Any ideas on what wires connect to what terminals??
    Ive searched for hours lookng on sites at wiring diagrams but nothing seems to match my car?
    It a 1998 impreza wrx turbo jap import
    May 2011
    I am not quite sure what to do with the wiring to the mass air meter, but I'm pretty sure a mechanic can help resolve your inquiry. Hope this helps.
    If the car ran before you re-connected the MAF wiring, some other means were used to measure air flow. Does the car use a different ECU, is it modified, or?
