Smoke from the hood???
Results 1 to 3 of 3
This is a discussion on Smoke from the hood??? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hey guys, need a bit of help here. I drive a 2002 Subaru Impreza WRX. Have about 78,000 miles on ...
    Mar 2010
    Exclamation Smoke from the hood???
    Hey guys, need a bit of help here. I drive a 2002 Subaru Impreza WRX. Have about 78,000 miles on it. Recently noticed that some smoke (white color, not black) was coming from under my hood. It only happens when I am stopped and there isn't a huge amount, but enough to notice.
    I asked a technician and he says I might need to repair my water pump and that he'd charge me $800. According to the maintenance schedule though, I shouldn't have to replace it until 105,000 miles. Any ideas what may be the problem? I did notice my engine coolant levels were low.
    Any suggestions would be appreciated. Thanks!
    Mike
    Find the leak. It's either coolant or oil; likely coolant from what you say. $800 is too much for just the water pump; although there is a lot of labour involved you are likely to find it cheaper elsewhere. Also, "might be" doesn't work. Ask around for a trusted shop and have them pressure test the cooling system (less than $100 if the leak is not immediately evident to them. If the leak is obvious to them, make sure you get a more reasonable estimate for repairs.
    Les jeux sont faits.
    Registered User GarrettKoonsman's Avatar
    Apr 2009
    CO
    Quote Originally Posted by Mike515 View Post
    Mike
    Coolant leak? Possible radiator crack or hose sliced?
    2003 Midnight Black Pearl WRX Sedan
    200.7 AWHP Protuned Stage 2 at 5400ft above sea level
    Bugeye Mafia Member #225
    Mods
    Pics
