Adding coolant.
Results 1 to 13 of 13
This is a discussion on Adding coolant. within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; My coolant level is less than the lower level. I was going to add some but i don't know what ...
    Registered User zeus32's Avatar
    Mar 2010
    Albuquerque NM
    Adding coolant.
    My coolant level is less than the lower level. I was going to add some but i don't know what coolant was last put in it; the OM says DO NOT MIX COOLANTS. Do i need to do a flush or can i just add as long as the coolant is the same color?? Thanks
    If the level is low find out why and fix it.
    There are coolants that are universally compatible with any other coolant; Peak Global comes to mind. These will say so on the container. Or, just use distilled water.
    Apr 2004
    Southeastern PA
    I always use distilled water in the cooling system. Some municipal water supplies are high in various minerals (hard water).
    Moving to: General Maintenance, Troubleshooting & Accidents.
    Mods & Pics
    Mar 2010
    Albuquerque NM
    distilled water
    So just add distilled water to whatever coolant is already in there? That's it?
    Apr 2004
    Southeastern PA
    Quote Originally Posted by zeus32 View Post
    If you are only low by a relatively small amount, yes. Can you see how much by the level in the overflow tank?
    Mods & Pics
    Mar 2010
    Albuquerque NM
    Its about a inch past the low line, I also don's see a radiator cap. Do i have to remove something to get to it? Thanks sir
    Mar 2010
    Albuquerque NM
    Quote Originally Posted by 04.SPT.WRX View Post
    If your car is a bugeye it may only have one radiator cap, and confusingly enough cars like that (mine included) do not have the radiator cap on the... radiator. They have it on a reservoir toward the top and passenger side of the engine, near the turbo and near the passenger side strut tower.
    Mar 2010
    Albuquerque NM
    The car is a 02 wrx, the only cap i see is a yellow cap on the driver side.
    Mar 2010
    Albuquerque NM
    Ok i found the cap in front of the turbo. Thanks, here's a amateur question for you. Do i add coolant directly into the metal radiator cap or just fill up the reservoir (plastic cap)?
    If there is no fault in the system generally the radiator cap is left alone between flushes (that is, for ~30,000 mile intervals). So in a healthy car just top off the "white" plastic reservoir on the nose of the car near the driver's side headlamp.
    In a car that's not healthy... find the leak and fix it. Sorry, not followed your other posts -- do you smell any coolant or see any white or green residue or juice anywhere?
    Mar 2010
    Albuquerque NM
    No coolant smell and i've never spotted any leaking fluid anywhere. I think its all good. Do you know where i can find a post on how to flush the radiator? I know I'm supposed to know how to do this but i'm a youngster and don't have much experience with mechanics. Thanks for being so helpful.
    It's very feasible but it's not much fun. Read this, it covers a complete rad install and will familiarize you with the system:
    How To: Install aftermarket radiator (Koyo racing rad), and flush the coolant - IWSTI.com: Subaru WRX STI Forums
    You will need to find the drain plug on the lower passenger side of the rad, hidden by the metal rail under the rad. To do so either remove the air intake "funnel" piece from the nose and look down the side of the rad or go under the car (NEVER get under a car on a jack! Either leave it on the ground safely on four wheels or use ramps or jack stands!).
    Also look through these threads:
    ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums - Search Results
    As a whole they contain info on burping the system (this is CRUCIAL) and tidbits here and there. Since you're not doing it tonight (it's 22:00 PST on a Friday!) there's some time. If you're still up for it, tackle it only after reading up in my opinion. Also, have the correct coolant (either Subaru factory stuff or something like Peak Global that is compatible with everything under the sun) plus some distilled water and lots of time and patience.
